- Dec 8, 2009
- Reaction score
- 2
- Location
- Evansville , IN.
- Make / Model
- Ford
- Engine Size
- 4.0 OHV
- Automatic
It's real close .
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Thanks DustinAt the bottom of the tech library writeup:
These hoses are 26" long:
Raybestos: BH 38622, BH 38623
There are 2 numbers because there is a right and left side
http://www.autozone.com/autozone/parts/Brake-Hose-Front/_/N-8knp9?filterByKeyWord=BH+38622&fromString=search&fromType=oem
http://www.autozone.com/autozone/parts/Brake-Hose-Front/_/N-8knp9?filterByKeyWord=BH+38623&fromString=search&fromType=oem
I forgot about that . Yeah first time out with the 44 stuff and it looks like it lost a cap off a joint . But that is my fault . I did all that work and didn't put in new joints , I just tack welded the caps on some used joints to the shafts . New 5-760x joints and full clips will be going in before next weekend .the broken shaft sucks...so far so good with everything else though, it did good
Yes , got the spring at Four Seasons on Morgan .When you did your gears, did you do the c-clip elim. And if so what/where did you get the spring?
