My Yellow 2006 Ford Ranger
jackham
5
Florida
Good evening,
Am new to this site
I have a 2006 Ford Ranger super cab automatic RWD with a 3.0 liter Vulcan. A year ago I had a misfire because ford and their infinite wisdom decided to change the valve stem from 8mm to 7mm. TSB 05-26-3 DTC’S P0300-P0306 and P0316 so I ended up changing the heads . Truck had 115,000 changed timing chain and gears . Did an upper refresh new water pump injectors , cam synchronizer , crank sensor, oil pump all new gaskets. Now truck has 230,337 and still running i can’t kill it ! Love my 2006 ranger it’s my daily driver! About go get a 2018 F-150 sport with the 3.5 liter ecobost it has 79,000 miles
CamTheHedgehog
ASE Certified Tech
419
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
Welcome! Not too often you see the yellow rangers, but I think the color goes well with them.
As for the engine, now that you have gone "back" to the 8mm stem heads, those Vulcans are bulletproof. Anemic, but bulletproof.
Just change the cam synchro every 60-80k or so.
RobbieD
2.9l Mafia
3,584
Georgia
Welcome!
That is a good and bright yellow; very nice truck!
superj
2,722
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
welcome!!
someone near me is selling a yellow single cab step side with the 3.0 and five speed and i always look at it because the yellow is such a different color that hardly anyone has.
i like my 3.0 too. mine has 216k now and i would drive it across the country without thought.
pjtoledo
3,010
Toledo Ohio
Fords
3.0 2.3
judging by where your left foot is I'll wager you were complaining about the seating arrangements.
