Mystery's 99 Ranger Build
Mystery Leak
Albany, NY
2.3
Mystery's Machine
3.0 DAILY DRIVER
9/5/12 Sold Truck. Parts FOR SALE <click here>
8/25/11 Hazards Out - Replaced Flasher Relay.
8/21/11 Belt Squeal - Replaced Belt and Idlers.
8/18/11 ABS Light (C1230) - Replaced Speed Sensor on Rear Differential.
8/17/11 Radiator Hoses Collapse - Replaced Radiator Cap.
8/13/11 Engine Reassembled and it STARTED UP!!! Serpentine Belt Squeals.
7/23/11 I'm currently in the process of replacing the heads on my 3.0 V6. This is the first time I've ever worked on an engine so there's lots to learn. For now this will be a DAILY DRIVER BUILD as my focus will be on fixing the stock engine. I'll post hints and tips I pickup along the way.
History: Water Truck 1
I'm calling my project 'Water Truck 2' in honor of my last truck which was a 98 F-150 4x2 with 150k miles that I got from the local Water Dept. They put it up for auction on eBay and I ended up putting in the winning bid of $1250.
I only kept it 8 months because I blew out the tranny after getting stuck in mud. I lost 2nd gear and reverse, but still managed to drive it to the junkyard and collect $100.
Current Build: Water Truck 2
I got this little gem on the WandAdDigest.com for $500. It's a 1999 Ranger XLT 4x4 with 3.0L Flex Fuel V6, automatic. I'm new to engine repair, so this is going to be my low-cost learning tool.
Problems
Mystery Leak - It was advertised as needing heads or possibly just head gaskets. I spoke to the guy and he said there's a coolant leak. There are no puddles underneath the engine and no coolant in the oil and it's not billowing white smoke. It's also not taking in coolant from the overflow tank either. A mechanic told him to put a rag on the tailpipe and see if it smelled like coolant which it did, so there's some sort of internal leak. Before I drove it, I opened up the radiator and made sure the coolant was topped off. The water temp stayed normal for the trip back. I also had the windows open and heater cranked to max for some added insurance.
176k mi - This engine has seen better days. It runs rough and lacks power. It was a struggle to keep up with traffic. I don't know if it was the engine or the tranny or both. I'm hoping a healthy 3.0 has more power than this one.
ABS Light - it was on for the whole trip.
DTC P0305 - I hooked a scanner up to it and throughout the trip it'd blip P0305 Misfire on Cylinder 5
Intermittent Oil Pressure - I checked the oil level before I left and it was normal. About halfway through the trip, I hit the overdrive lockout button and soon after that, the oil pressure gauge started to spaz out and then flat-lined. I was worried that I lost the oil pump so I pulled over turned the engine off, waited a few minutes and then started it back up. The rest of the way back, it was still spazzy so I kept extra light on the throttle to keep the gauge normal.
Whine - heard a constant whining noise throughout the trip. Not sure what it was.
Body - The cab in great condition with very little rust. The paint is pealing off the front bumper and the rear has nearly disintegrated. The bed got rear-ended on the right side, so it's got a good crunch in it. The tailgate is frozen shut as a result. The handle is broke on one side and the latches seem to be frozen. The fiberglass cap latch is busted too, so it won't shut or lock.
This is where it stands so far. Feel free to make comments and suggestions!
bilzy7
32
Lynn, MA
4.0 SOHC
Hey, truck still looks good. Good luck with an engine swap. Hope to see progress.
bilzy7
32
Lynn, MA
4.0 SOHC
Same here. I was trying to buy a 300 dollar one but guy never responded... It only had a break leak and 270k miles haha.
Mystery Leak
Albany, NY
2.3
Parts Shopping
Been doing a ton of window shopping at ebay, craigslist, wantaddigest, NAPA and SUMMIT while I plan out the next stage of the build. Here are some things I bought:
Ford OEM PATS Transponder Chip Key Blank
Wolf Security Hardware thru ebay
$13.95 + Free Shipping​
This key blank is made by Strattec....they are the OEM for this part. Ford buys this part from Strattec and packages it under the Ford name. It has the same appearance, specifications, and quality as those sold under the Ford name.
This key is unprogrammed....it will NOT crank your vehicle until it is mechanically cut to match your key AND electronically programmed to match your vehicle's computer.
This key blank is unprogrammed and must be programmed AT THE VEHICLE before it will crank the vehicle.
You can program the key yourself IF YOU HAVE TWO EXISTING KEYS which are already programmed to crank the vehicle....otherwise you will have to hire an automotive locksmith or Ford dealer to program the key with special equipment which is connected to the vehicle. There are a few exceptions to this "two key" rule...contact me if your vehicle is made in 1998 or BEFORE.
Below is the on-board programming procedure. Remember....it only works if you already have two working keys....there are a few exceptions...contact me if your vehicle is made in 1998 or BEFORE.
Add Duplicate Key (Requires two working keys):
1. Insert an existing key into the ignition cylinder.
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing key and, within five seconds, insert a second key and turn it to ON (RUN) then back OFF.
4. Insert the new key before ten seconds have elapsed and turn it to ON (RUN). Leave it on for one second and turn back to OFF
5. The security light will light up for three seconds to indicate that the new key has been successfully programmed.
Remanufactured 3.0L V6 OHV Heads
Dover Cylinder Heads thru ebay
$200 + Free Shipping​
Heads are Totally Rebuilt from Premium Castings, and have been Upgraded with Tungsten Carbide Alloy Exhaust Valve Seats to eliminate the exhaust valve seat recession problems common to the Ranger trucks. All components have been thoroughly cleaned, inspected, and replaced where necessary. All heads are machined in our facility using State-of-the-Art equipment and procedures. All heads are assembled with High-Temp Viton valve stem seals and thoroughly tested to ensure optimum operation of all components. Heads are completely assembled and ready to bolt on.
I think I'll work on the cooling system while I wait for the heads to come in. After I drain the coolant, I'll flush the system and then replace the water pump and thermostat. Maybe I'll throw in some new hoses and sensors too. The NAPA down the road is gonna be seeing a lot of me over the next few weeks :)
Mystery Leak
Albany, NY
2.3
I changed my mind and went with RockAuto instead. I like how they offer Motorcraft parts at reasonable prices. I got radiator hoses ($54), a thermostat ($9), radiator fan clutch ($107), water pump ($109), blower motor resistor ($18), camshaft synchronizer ($96), new spark plugs ($22) and wires ($28), misc oil pressure switches and water temp sensors. My shopping spree ended up setting me back around $500.
My heads came in from Dover Cylinder Heads. I have a Flex Fuel 3.0 and these are the non-flex heads (F6DE-GC castings). The guys at Dover said they would be compatible, so I'll just take my chances and install them. I'll let you all know if anything goes wrong.
Here are some random pics I took of the truck. These will be the BEFORE pictures.
stiluv
01/2014 OTOTM Winner
ASE Certified Tech
nevada city, california
5.oh face oh oh oh
Solid Axle Swap 4x4
the non flex fuel heads will work fine you will heva a little bit lower compresion thats all. before you put the heads on you should do a little porting on the heads and intake. it will open that 3.0 up a bit
Mystery Leak
Albany, NY
2.3
Thanks stiluv, that's good to know! I dunno if I'll be patient enough to port the heads and intake now. I sorta wanna get this thing up and running ASAP. Then again, I don't wanna spend another $150 for gaskets and bolts if I change my mind later. Hmmm, tough decision!
I took one look at the location of the Camshaft Synchro and decided to quit while I was ahead. The thing is buried deep below and behind the intake under a big bundle of wires. I'll do the job when I replace the heads. Right now, there's just too much stuff in the way!
On a different note, I finally found someone to cut my PATS key. I tried Home Depot a week ago and the kid there said he wasn't allowed to cut keys with transponders. Then I tried at the ACE Hardware and they said they don't do it either. The guy at ACE recommended a locksmith the next town over, they were closed by the time I got there, so I was rather annoyed and called it a night.
Today, I went to a different locksmith to see if he could do it. As I was waiting in line, I saw that they had the STRATTEC bags plastered all over the wall along with their key blanks. When it was my turn, I asked the lady if she could cut my key, she asked if I had two keys and I said yes to which she answered yes. (You can program a new key in your truck if you have two keys. If you only have one you're outta luck and you have to go to the dealership and pay them around $80 for them to reprogram your PATS computer.) She said she had the same blanks too and that they cost $20. It cost me $5.40 to cut the key and $13.95 for the key off of ebay ... I guess I didn't save all that much. In any case, I got me my new good luck charm and it comes complete with Ford Logo and PATS security chip! :D
stiluv
ASE Certified Tech
5.oh face oh oh oh
Solid Axle Swap 4x4
any progress?
bilzy7
32
Lynn, MA
4.0 SOHC
You should send me your rims!!!
bilzy7
32
Lynn, MA
4.0 SOHC
And throw that friggin camper top away!!! Lol
Mystery Leak
Albany, NY
2.3
I haven't made much progress on the engine. I've been picking up stuff I'll need for the head swap: containers to drain the fluids, fuel disconnect tools, a Craftsman torque wrench, RTV, radiator fan tool and a bunch of other odds and ends.
Mystery Leak
Albany, NY
2.3
I finally started tearing into the engine after work today. Thanks for the nudge you guys! :)
This is my first time working on an engine so I did a lot of things for the first time today. I warmed up the car for 15 minutes and then unscrewed the plug in to bottom of the oil pan and watched the oil drain out. I missed the bowl a few times, so I'm glad I bought the extra large "pizza pan" splash tray. I managed to save the driveway from oil stains, but the antifreeze was a whole nother story.
I didn't know where to drain the coolant from. It's a good thing I had my computer up and running. I did a quick search on TRS and found this thread -->http://www.therangerstation.com/forums/showthread.php?t=89891<-- with pictures too. I tried the stopcock, but only a few drips came out. I'll bet it was all filled up with crud. When I opened the radiator cap, it was covered with what looked like mud. Not sure how that got in there. Anyways, I decided to use the shortcut that mixwell suggested and started to drop the bottom radiator hose.
The hose was almost off when the coolant came out as a small jet, missing my catch basin, and my drip pan and landed on the driveway. I pushed it back on and off trying to varying the size of the jet. I kept missing my target and worse yet, I felt like I was milking a green cow. :icon_confused: Finally I threw a rag over the works and gave it a good tug. Most of the coolant drained in the pan and rest, well, became my cologne.
I found a good writeup on how to remove the serpentine belt and stuff on -->http://stuffforyourranger.com/How_To_Installs/30underdrive.html<--. It just happened to pop up on the 3.0 forum the other day. This link -->http://stuffforyourranger.com/How_To_Installs/removemechanicalfan.html<-- gives another visual for using the radiator clutch removal tool. You only use the crows foot from the kit. I wish they would sell that tool alone. When loosening the 10mm bolts on the fan pulley, I found it useful to put pressure on the socket or bolt with a finger so I could get the socket wrench to ratchet. It's kinda obvious, but it didn't seem so, when the bolt and socket were hidden by the pulley and it stopped ratcheting after the first few turns.
I also didn't know you could release the belt tensioner with just a regular 15mm wrench. Saved me from having to buy a serpentine belt tool.
After I got the fan clutch off, I pulled that, the fan and the radiator shroud off and called it a day.
Mystery Leak
Albany, NY
2.3
I headed over to Hoosick Falls yesterday to picked up a new bumper for the truck. Craigslist said it was a complete rear ford bumper - includes top step pad, black bumper bar, license plate lights and right and left bumper brackets. It's from a 2008 Ranger and only has a few thousand miles on it. I bought it for $175.
Guess I'm gonna have to add brake lines to the list of things to fix.
Speeds 1 & 2 on my Climate Control aren't working. It only blows air on Speeds 3 & 4. This happened on my old F-150, so I figured it was just a matter of replacing the blower motor resistor. I couldn't get the connector off the resistor, so I took it out still connected. From there it took three small screwdrivers, an awl, a claw hammer and the better part of a half hour to get them apart. Looks like the contacts welded themselves together. Not going to be an easy fix.
Removed Alternator, Coil Pack, Upper Intake Manifold and Throttle Body. Disconnected Wire Harness and Vacuum Lines. Removed Fuel Line from Fuel Injector Rail using AC/Fuel Line Disconnect Tool Set (Lisle model# 37000 available from Sears for $10).
Got stumped by the bloody A/C Hose Mounting Tab which seems to have been mangled. Couldn't seem to fit a wrench or socket on it. Couldn't remove the A/C Compressor or the Alternator Bracket with that in the way.
Managed to get the A/C Hose off by drilling through the pop rivet holding the Mounting Tab together. Removed the Mounting Tab still attached to the Water Pump stud.
With that out of the way, I was able to remove the last bolt holding the Alternator Bracket. I also removed the Radiator, Upper and Lower Radiator Hoses, Spark Plug Wires and Belt Tensioner.
I used a metric open end box wrench when undoing the transmission cooling lines. I used a large adjustable wrench to hold the larger fitting, while I used the open end to undo the compression fitting. I was worried about fluid dripping out of the lines, but hardly anything dripped out when they were disconnected.
Mystery Leak
Albany, NY
2.3
Rented a Power Steering Pulley Puller from Autozone and removed the Pulley. Removed AC/PS Bracket. You can see what tools they've got for renting -->here<--. Basically you buy the item and then return it for a refund when you're done.
Pulled the plugs and did a compression test. The remote starter switch came in really handy.
Ford sure makes it tough to get to the starter relay. They mounted it on the starter, so I had to crawl under and find the ignition terminal by braille. I wasn't able to warm up the engine since it's in pieces right now - but the results of the wet and dry compression tests seem to show that the cylinders and rings are Ok.
Cylinders 2&3 are low. I'll bet that's where the leaks are!
Not sure why Cylinders 1&4 are so much higher. Carbon buildup maybe?
Compression Test Results (psi)
1) Dry 193, 197
Wet 201, 203
2) Dry 115, 115
Wet 126, 111
3) Dry 129, 123
Wet 111, 111
4) Dry 195, 190
Wet 190, 196
5) Dry 158, 160
Wet 165, 168
6) Dry 157, 158
Wet 168, 164
Notes:
- Engine was cold.
- Did way more than recommended 5 pulses, basically kept running until needle stopped moving.
- Ran the battery down too much, wet test results may be off. Had to run with 30A battery charger on last few wet tests.
