Need help with coil spacers leveling kit.
peclarkjr@msn.com
Hello guys,
I have a 91 Ford Ranger 4x4, 5spd, with the 4.0L. I just bought 35x12.50 BFG MTs. The truck currently has about 7 inches lift. A 3" BL and supposedly a 4 inch suspension lift. The rear suspension lift is just a 4 inch block under my leaf spring sitting on my axle. The front was replaced with an F-150 coil. I bought this truck last month so Im not sure how much lift F-150 coil springs actually give.
I want to get a level kit or really just a coil spacer about 2 inches for the front coil. My question is this. Since it is an F-150 coil do I get a spacer for an F-150 coil or the stock Ranger coil? Seems like to me it would be the F-150 but I have no idea since its probably mounted on stock ranger components.
I noticed Summit Racing has a large supply to choose from and I need to gain at least 2 inches for the 35's.
Another option is hacking and trimming my front fenders. I don't mind doing that with this truck because the body is pretty messy already and I'm using it for hunting and off road only on weekends. Are there any examples of how to creatively trim a fender?
I will up update with pictures.
Thanks!
Paul
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
It will probably depend on whether your truck has F-150 coil spring seats or stock or stock/modified seats which spacer you need.
The stock seats I recall are ~3.25" diameter around the base, the F-150 seats are larger (3.75" or 4" maybe).
Be aware you can only raise it a certain amount higher before you will then have to drop the axle pivots down lower to be able to align the camber. A good way to tell how far you can go is to measure where the center of the axle beam pivots are in relation to the center of your wheel hubs. In a majority of cases you can have the axle beam pivots be 3" above the height of the wheel hubs and still be able to align it using higher-offset camber/caster bushings.
As for trimming fenders, I used a fine-tooth blade on a Sawzall to trim mine (32 TPI, iirc). I used masking tape to create a line for cutting, and just followed along that. Covering the edge are Pacer "Flexy Flares" (surface-mount type). Should be a few pics of the fenders on my BII page (see link in sig).
peclarkjr@msn.com
Nice Bronco! I will send I do have one more question. I was told by another Ranger owner that has a similar setup that I might need adjustable ball joint cams. I'm assuming this will allow for adjustments to keep it with in the tolerance you were suggesting?
The Toyota I lifted was easy...I just threw a Revtek in there and it worked. For the Ranger there seems to be so many more options and any help is appreciated.
Thanks!
Paul
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Thanks!
Yeah he was probably referring to the eccentric caster/camber bushings that go around the upper ball joint studs. These are where you make your camber & caster adjustments.
I've always preferred the two-piece concentric bushings over the factory fixed-degree type (Ingalls #59400, Spicer/Raybestos #6122025, Moog #80109). These allow you to make a full range of adjustments without having to replace the bushings each time a different degree of offset is needed.
