Need OBD-II Trouble Code input
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
p0171: was a bad fuel injector also causing a dead misfire
p0400-p0404: DPFE sensor almost everytime lol
p1000: sets after codes are erased or battery is disconnected
p1051: you have to push the brake pedal down during KOER test, if not this code will set or the brake circuit has a problem
p1404: usually only on california vehicles, i've had a couple that the temp sensor was completely covered in carbon or the EGR passages were plugged
p0551: power steering switch had fluid leaking into the connector, replace switch.
thats all i feel like remembering right now lol, i just went down the list to see if i've dealt with any
a31ford
Electronics GURU
26
Brandon, Manitoba
2.9
Hey Jim (Assuming you have e-mail notification on this thread).
I have found the "GOD" Book (Sorry if this is over the top), it's an 85 Mb. PDF on Ford injection and computers,
Some 442 pages !!!!!!!
Because of it's size I would have to put it up on my web server so you could download it.
It's got "everything, about everything"...................
Let me know.
Greg Manning,
Brandon, Mb, Canada
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
^^^Would this be appropriate info for the backyard mechanic trying to learn obdII ?
If so, would you be willing to let me copy it?
Thanks,
Richard
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
8
Plattsburgh, NY
1999
4.0. 4.0 Supercharged
p01443, purge valve code.. almost everytime its the sensor or the solenoid... always be sure to check your pins i have seen them get the green disease
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Got it.
Sent from my SGH-I747M using Tapatalk 2
Sheppard Honor
svfdbgn
The PCM monitors voltage drop to determine coolant temperature. If the ECT reads less than freezing temp. when engine has been running for more than a few minutes, the PCM determines a circuit fault and sets this code. Or if the PCM determines the sensor resistance is out of specs, this code is set.
:icon_hornsup::icon_hornsup::icon_bounceblue::icon_bounceblue:
SirSantie
Sonora Mexico
Always Be Humble And Kind
So my truck is throwing up P0153, P0174, P0133 and last but not least P1152. Any suggestions as to where I can start?
