Need V-8 Swap Articles
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Hey guys,
We need some V-8 swap articles for our tech library.
We need a write-up from someone who has done a swap on a 98+ and newer Ranger. We need both a 4.6 and 5.0 article with emphasis on wiring and any required conversion parts to help give our readers some guidance.
Thanks.
Mac
183
C. Wisconsin
2000
199
Jim,
There is a very good write up in the tech library on using the Explorer 5.0 motor in the later Rangers. It needs a little tweaking to explain maybe why that's the motor to use. Main problem I have seen is that the newcomers are not used to using the tech sections, usually it's all there. Maybe at the top of the V-8 section, in bold letters, CHECK HERE FIRST IF YOU HAVE A '98' AND NEWER RANGER and have that link there. GregR is the only one I know of that has done the 4.6 swap into a later Ranger.
Dave
Jim Oaks
Administrator
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Well, I put that article together, but we can always use more info. We don't have any 4.6 articles.
TOPDOG2007
August 2010 STOTM
6
Ga
I am interested in seeing more info on doing the 93-97 Ranger..Explorer 5.0 swap. Especially on wiring the factory explorer harness with the Ranger and why its supposed to be a nightmare.
TomB1269
Capital District NY
2002, 2005, & 2
All Fords
3.0L/4.2L/5.4L3V
Gents, I have scoward the net for OBDII V-8 swaps in the ranger, as I have an 02 and would love more power, and every thing seems to stop as soon as the Explore went 4.6. I have heard there are other streetable issues with the 4.6, as in Ford did not make a compact truck with one so it will not pass emissions due to the fact that the engine is not a OEM option in this class of vehicle, and you have to have model year or newer more, never mind PATS issues, ECM and cluster problems.
MudSlanger
Ill probably have a fully detailed 5.0L swap forum posted probably in the next few months.
Im swapping a 99 explorer 5.0L 2wd auto in to my 00 ranger 3.0L 4wd auto.. I will be keeping my ranger transfer case so i dont have to build new driveshafts. There is also an adapter kit that will transform my 4R70W 2wd tranny into a 4wd that my ranger transfer case can bolt up to. No other modifications will be needed to my knowledge except having my exhaust redone and the PATS system reprogramed through the FORD dealership. Ill probably go ahead and buy the torque monster headers for better mpg's and a little more horses :) Other than that the motor will be pretty much stock. Ill be using the Explorer motor mounts since they will all fit in the ranger. The radiator part will probably give me the biggest issue as to I really dont know what kind i want yet. I heard the 4.0 ones are good BUT require modification.. 5.0L one works and i do believe thats a direct bolt in. dont quote me on that. Im retaining all emissions and AC because this will be my daily driver. Ive been doing a ton of research on this topic and pretty much i think i have it all down. Now im waiting on the guy to pull the motor and all the parts i need to make this swap work and ill be set.
Ill have plenty of pictures of the process.
The 99 explorer(8 cyl) and 00 ranger(6cyl) have a lot of similarities when it comes to electronics. Both vehicles use type B in the PATS system, also they both use a returnless fuel system, and both read vehicle speed through the VSS/ABS from the rear axle. So this swap should be fairly PLUG AND PLAY. I think i read somewhere ill need to adjust my wiring for the AC but ill figure that out once i get the motor running. Also have to swap a wire for the tach and pretty much should be the only thing ill have to mess with electrical wise. WHEW thank goodness lol
PS: Jim i bought that Advance Adapters 9 inch AOD to 1350 kit from this site to start things off :) Cant wait to get it and take lots of pics of it lol
4.6stranger
wyoming
4.6
Any updates on the OBD II 4.6 swap? I swaped a 1996 OBD II mustang 4.6 and t-45 into a 1994 2wd Ranger I might be able to find some pictures and do a little write up if anyone is interested.
onehotpocket
4.0 SOHC
I'm actually inthe process of doing this right now. I have a 2000 ranger that had a 2.5 in it and a 351w out of a van that's going into it. I'll be sure to take pictures And let you guys know what sort of difficulties I run into. I know this isn't the exact explored swap you're thinking of, but ithink it'll be interesting none the less. I've yet to see some documentation of a 351w in a 98+ ranger.
thanks, Dave
Spowerback
Banned
--- Banned ---
California
FORD
v6 4.0L /
302 cid or 351w 460 or later choice 342ci minus or v6 3.0L-4.0L bbk supercharged 8psi
chvlfrk
December 2010 STOTM Winner
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
5.0L
235/70R15 front / 275/60R15 rear
I picked up a 99 last week, that is gonna be the new foundation for my RAT Ranger build,:icon_welder: and I will take pics as usual.
DRAGONDOG
i have a 97 f150 single cab long bed v6........this guy is gettin rid of his old beat up f150 with a 1990 305 in it (5.0 V8) i dnt know whatt yr his truck is if its a 90 or older.....my v6 blew a head gaskit so i already pulled it to do a overhaul on it.....will this 305 fit in my truck
White94Ranger
Aldergrove B.C
2.3
that engine would be a 302 and yes it would fit just grab the engine mounts with that truck in weld or bolt it to you truck
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
i'm not sure what wiring issues you guys are talking about,but when i first went mid engine on the ranger it was with a 98 4.6 from an f150....the wiring was pretty straightforward,just got a haynes manual for the schematics...if you have access to alldata it will fill in most of the gaps.many repair shops will print out diagrams for a small fee if you ask nicely.edit....after looking at this pic again,it does look a bit of a rat's nest there...dosn't it!
ranger joe
monroe ,la
ford (2) , bu
here is my baby .
97 ranger 306 hypertenic pistons .030 over . motifed e6se heads ,ported .194 in .154 ex vavles , e 303 roller cam , comp cams roller tip rocker , holley 670 cfm truck avenger, proform 1 wire distributor, apx. hp 340-370 @flexplate.custom gauges.fox body oil pan and pick up tube . all build pics are in my profile .more on the custom gauges i will have more pics... i dont how to get pics off my puter to this page?
No members online now.
