o2 sensor locations on 1990 2.9l v6 ford ranger
stamina
34
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
i know there is one right before the catalytic converter, that is all i know as of now, where (if any) are the other ones
RobbieD
2.9l Mafia
3,464
Georgia
Should be only one on a 1990 2.9L.
stamina
34
Wilmington, NC
4” suspension
265/75/r16
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
that word should🤦‍♂️i appreciate your feedback though🤙🏼
You should be able to find that info in the wiring diagrams.
You should be able to look at your exhaust and see how many you have.
RobbieD
2.9l Mafia
3,464
Georgia
My 1990 Bronco II has only one HEGO sensor. The 1990 EVTM (Ford wiring diagrams) shows only one HEGO sensor on the 2.9, both Federal and California.
So yours "should" have just one, but anything is possible on a 30 year old truck.
stamina
34
Wilmington, NC
4” suspension
265/75/r16
is a 'HEGO' sensor different than an o2 sensor? and is it right before your exhaust?
RobbieD
2.9l Mafia
3,464
Georgia
No, HEGO is the same as O2 (Heated Exhaust Gas Oxygen). On mine it's on the Y-pipe before the cat.
stamina
34
Wilmington, NC
4” suspension
265/75/r16
thanks so much got it figured out!
SCOTTY
121
Above the equator
Ford Ranger XLT
Cologne 2.9 V6
Where is the fusible link ?
8,370
On a 1990 2.9l the O2 sensor's heater should be fuse 18 in cab fuse box, 10amp
SCOTTY
121
Above the equator
Ford Ranger XLT
Cologne 2.9 V6
Thanks ! So there is no Fuseable Link as well under the hood ?
