Intermediat+OverDrive Bands tightened via 2 Studs with 2 Nuts on Left Drivers side of Transmission
Tightening Procedure:
~ Hold BandStud In Place, Loosen JamNut
~ Tighten BandStud To 10LbFt 120LbIn CW Then BackOff 1.50~2.00 Turns CCW
~ Hold BandStud In Place, Tighten JamNut To 35~45LbFt
Video specificly on adjusting the Bands
More details in these threads:
2003 Explorer 4x4 4.0L XLT with Automatic Transmission I am getting ready to adjust the bands on my explorer and have a couple of questions 1.) What temperature should the transmission be at when adjusting the bands 2.) When adjusting the bands, I have found that the locking nut can be...
www.explorerforum.com
I cut open my transmission filter because it was the first oil change since the rebuild 30k on this filter Here is what I found any thing to worry about Also when I was checking for leaks out of pure curiosity I reached up and tried to turn the band adjustment screw it unscrewed it wasn't...
Hey all, New to the forums - found a wealth of information about fixing the transmission issues with my '97 2WD Aerostar, especially Glacier's valve body diary. This is my first time doing any work on transmissions. I'm now in the position where I have a new (remanufactured, ShiftRite) VB...
Band specification chart. A4LD: All Intermediate bands are single wrap. Single wrap band = 2.0 turns back. 1990-1992 Overdrive bands are double wrap, except in mid 1992, which went back to the single wrap band. Double wrap band = 3.5 turns back. 4R44E/4R55E 5R44E/5R55E/W/S/N: Single...
long story short, I have recently installed a transgo shift correction kit on my 2004 Ford Ranger 4x4 4.0l and I adjusted the bands accordingly, now I have saved up and bought an original Ford 5r55e valve body with Updated solenoids seals and gaskets. I'm wondering what to adjust the bands...
