Phenolic vs metal
Denisefwd93
74
South East PA
Caliper Pistons! Almost always that's what you get unless you specify metal piston calipers. Why do they continue to make this junk and is it actually junk?
8,372
Phenolic is heat resistant resin, it transfers less heat to brake fluid and dissipates heat faster than metal pistons.
Also lighter.
But not good for heavy brake use, i.e. hauling loads
So not junk, for cars and light duty trucks they would be the correct choice.
Metal would be for more heavy duty use, and you can rebuild metal calipers yourself
If you have a piston problem, phenolic or metal, it is not usually caused by the material, its a brake system issue.
I have had more metal caliper failures then phenolic, but in fairness metal has been around ALOT longer :)
Metal can cause rust rings in the cylinder if vehicle sits for long periods, so piston doesn't move as freely, causing dragging pads
Just an opinion
Denisefwd93
74
South East PA
Ron I'm kind of locked in the mindset of thinking some plastics are not as dimensionally stable as metal. It appears the phenolic they are using for these Pistons is pretty well-established as okay for "normal" duty.
Denisefwd93
74
South East PA
It would appear the Pistons in the calipers I got from AutoZone have metal
Phenolic caliper pistons are not just plastic. They are a phenolic glass resin, something like a high grade ceramic.
In addition to the advantages Ron mentioned they are not prone to corrosion, so if you don't get your brake fluid changed out on schedule the piston does not corrode, and jam itself in the bore as quickly. It can still happen, just not as fast.
The biggest issue I have ever had with phenolic calipers, and this is almost exclusive to Super Duty trucks, is that if the caliper had fozen (so you need one anyway) and overheated you will almost always fracture the piston while trying to remove the caliper.
