play in steering wheel
MvancE30
jersey :(
I have some massive amount of play in my steering. It seems that the tires follow the road and will drift left and right while holding the steering wheel in the same position.
im pretty sure that link is the issue. theres play in that. So how can i fix it? i was thinking of two flat pieces of metal (like a finger splint) but i figured this might have been addressed before. I did search but being a noob, i didnt find any answers.
RavoHimself
8
enfield, ct
try a new steering shaft from a jy that has less/no play. i need to do that too. i can probably go 1/8 turn with mine.
MvancE30
jersey :(
same here. what/who is jy? do you know the price off the top of your head? hoping for a cheap fix
kevinsranger
edison nj
FORD
what area of jersey are you from? you can try lmc truck, or pretty much all the junk yards in jersey will have them, just gotta bring yours to match up
RavoHimself
8
enfield, ct
Jy = junk yard
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
That is the rag joint. You can buy them new and they are fairly easy to replace. I don't see the reason for buying a used shaft from a junkyard and possibly having the same trouble that you already have.
MvancE30
jersey :(
ill look online for a new one but im from central nj.
what had to be done to the steering because of the lift?
kevinsranger
edison nj
FORD
it could be play in your steering box, there's an adjustment screw on the box itself too, i havent searched for the thread, but there's a thread here that tells step by step to adjusting it, not much to it at all.
me and a few friends are gonna go wheeling in jackson in about two weeks if you wanna joint. i'm from south brunswick
MvancE30
jersey :(
is that yours with the stacks on ridge? and im down. ordered a new clutch last night so hopefully its here and broken in on time
kevinsranger
edison nj
FORD
no stacks for me, i think i've seen it around tho, i don't have the heart to put stacks on my truck
what clutch did you go with? i just did the m50d swap into my truck, but the clutch is chattering, so i'm gonna swap it out over the winter
oh an this is mine, you may have seen it around if your local, but i just did the washer lift and put some newISH 32's on it lol
MvancE30
jersey :(
never see it around. im near 5 points or whatever people from sb call it.
SACHS Part #K004707
hope its the right one. lol
whissiswheelin
Mission BC
FORD
2.9L
I did the adjustment on my steering box a few weeks ago, easy, just loosen the nut, tighten the screw until the play stops and then tighten the nut again.
avenger
Central Ohio
2.3
Mine has Really bad play as well, i saw a bolt on it with a flathead screw on it..it wouldent budge, is there a trick to it? Maybe i just missed the nut...i saw the other post on another site awhile ago.
