PlumCrazy's Build
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
2 and 3 of 7...
ARP studs for carrier bearings in both axles
8.8 install kit and cross pin bolt.
Sent from XT907 using Crapatalk
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
4 and 5 of 7....
Wheel bearings, and inner axle seals. One wheel seal is MIA?
Picked up tcase off Brad last weekend. Going to see if I can fix my manual case with electric case parts again.
Robert_1967
13
White Pine, TN
302/2.9
What are those big weights for that they put on the back of the transfer case and rear axle???
Robert
posted using a red lipstick and gun power.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Vibration dampeners.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I don't have one. I used the mounting holes for the doubler mount.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Box 6 of 7 showed up..
Only things I need to get my hands on now are spindles, rotors, pads, and caliper brackets
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Past that mark months ago...lol
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
Oh well. No looking back now lol. Will this axle hold up to your lead foot?
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I still don't think I have a lead foot (maybe a brass foot)..I have seen a lot worse.
wizkid00104
13
2.3L/5.4L
I'll give you that lol. I look forward to seeing it assembled. How the new house and garage treating you?
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Working 60s Mon-Fri .....and its harvest time soooo my evenings and weekends are spent running the combine or hauling corn/beans.
Still working on moving in/finishing up the interior of the house. Kitchen remodel will wait till spring summer.
Garage is almost cleaned out...PO left all sorts of junk when they moved to a retirement home in FL.
I did haul the Ranger here and shove it in the garage tonight though. I need to get the 220 outlets wired up and replace the chimney pipe on the wood burner before the garage is ready for winter projects.
It needs some better like lighting and a decent air compressor too...but its a nice setup over all.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I need a winter beater too....I need to win the lottery and I'll be set for a while.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Dark shitty picture...but the blue turd is a garage queen now...
