Sand blasted the spindles and cleaned all the old grease out, knocked out the spindle bearings (which actually is a total PITA), painted them, and installed the Trail Gear bushings…which are awesome BTW. They just slip in and done…no thrust bushings to worry about. Only concern is that I no longer have the large wiper/slinger seal with the RCVs, so hopefully the grease rings keep the moisture out.
Painted up the hubs and brackets
One rotor showed up?
Got the axle under the truck for mocking up steering and track bar, then Ill pull it out and burn in all the brackets/gussets
Ran into some interference with the stock F150 track bar mount and the poly wedgie bushings…but its getting cut off anyways.
Bolted the knuckles up
The boots are a tight fit in the knuckle too….I might grind down the tip of the BJ a touch
Bolted the spindles and caliper brackets up only to discover high steer arm interference….not sure if its just this brand (Chassis Unlimited) or all arms on the half ton knuckles that have this problem…regardless a little grinder work and they fit like a glove…
I drilled the holes to ¾ for my rod ends and then it was powder time.
Blasted them down, plugged the tapered holes to keep coating out, I wasn’t worried about the straight holes, I can run a bit through them if needed.
Mounted everything back up
Steering angles are going to be nice this time…with my current pitman setup it will be less than a .5” drop….this means major track bar reconstruction. Looks like the engine cross member will be rebuilt based on track bar and SOHC oil pan requirements
Started playing around with one of the 15x8s…it was roughly 3.75” BS
The reduced diameter where the center is welded (the drop for mounting tire) is offset to the outside by a few inches….so I got the bright idea flip the centers in rim
I marked the welds in yellow
Carefully cut the welds
Used a brass punch and a mini sledge to push the center out
Sand blasted a little before the gun iced up. Sandblasting in -2* doesn’t work to well.lol
I flipped the rim and tapped the center back in, tacked it in at 2.5” BS. I used a straight edge and a sliding square to make sure the center was in straight. Not sure if the rib will clear the brakes, so Im stuck waiting for my studs and calipers to show up.
I sold the 12.5” bead locks I was running because they were just too damn wide for these tires. I didn’t like the side wall hanging out and the rim grinding against everything. Im going to weld on some 32 bolt rings to these 8” will make them around 9.25” wide. With the shallow backspace my overall stance shouldn’t be compromised much and the tire will stay off the radius arm. The HP axle will be 1” wider over all and the 8.8 with the conversion bearing retainers will side about 2” wider overall.
Who care is Dot approves? I don’t know who this Dot lady is…..but she doesn’t seem to approve of anything fun.
Before everyone freaks out about welding my wheels, and how straight they are, and how safe they are, and how my wheel bearings will be toasted……keep in mide these wont see the street..or 15mph for that matter.
