PlumCrazy's Build
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
Did a little excel work for a few ratios/scenarios. The yellow shows where I am now and what I am working towards.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Basically..my new 5th would be similar to my current 4th, but with a little better RPM range for the freeway.
036speed
02/2013 OTOTM Winner
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
:icon_thumby:
I guess I will start taking my axles apart :icon_welder:
kris97ranger
36
lisle ontario
4 litre and 7.3 litre
I need to final a crawl ratio calculator that includes tire size... im at 108.1 but thats without factoring in a tire
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I have FPM in there
Sent from my XT907 using CrapaTalk
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
What setup gets you to 108?
kris97ranger
36
lisle ontario
Not an rbv. My main wheeler is a toyota powered sammi. Still have 2 rangers but ones about to be scrapped to pay bills.
22re 5 speed dual cases 5:29s. On 38.5" tsls
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
Kris, I made an excel sheet that tells you your speed at a given RPM and tire size with your gearing if you want that.
Edit: Note, its in mph... not kmh
My email is 036speed@gmail.com
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
I put mine inn Feet/Min since at slow speeds, when MPH is a 1.XX or 0.XX its hard to get handle of how fast that really is IMO
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
PSH.
That is a good point. Mine is now in FPM lol. A much better scale for crawl speed indeed.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
^and the calculation is easier since there is no extra step for changing units of time.lol
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
I feel like there is a redneck joke in here....
If you truck is slower than a milling machine feed rate.... you might be a redneck...
Hmmmm.....
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
So I may need 2 cases or else I will be doing laps around you...
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Looks like you need to go for that ZF/1356 doubler setup on 40's....we will be even....lol
Then there will be the B2...4.10s and 31s, no doubler, no ****s given...showing us how its done.lol
EDIT: Apparently TRS auto censors the f-bomb...
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Another thing we haven't factored in is the actual rolling diameter of a big, squishy tire at 7-10 psi..lol
