- Apr 13, 2009
- 5,096
- Calgary, Canada
- '91, '80, '06
- Ford, GMC,Dodge
- Engine Size
- 4.0,4.0,5.7
- 2WD / 4WD
- 4WD
I was perusing thru some different websites and ran across some propane stuff. One mentioned an in tank pump for liquid propane efi. Another mentioned aftermarket fuel injectors for liquid propane. I did a quick search and a 20lb tank can range from 20psi at very cold temps to 200psi+ for tanks in the sun. Until it gases off the temp is the same as ambient.
Could I adapt the ford frame rail return style fuel system to run liquid propane?
Would a stock fuel pump pump liquid propane?
There would need to be a new fuel map produced to run the engine, so I imagine a mega-squirt or similar?
How hard is it to program such a map? Do I need to learn any particular programming language, if so which one?
@PetroleumJunkie412
@snoranger
@RonD
@bobbywalter
@PetroleumJunkie412
@snoranger
@RonD
@bobbywalter
