rear drive shaft
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
So will any explorer rear shaft work if I shorten it and put front flanges on it
Use a double-cardan Explorer front driveshaft (the shaft will need to be shortened approx 2" if you have the M5OD, FM146 or A4LD trans in your '89).
You'll also need a front yoke off a 1354 t-case to put on the rear of yours, and a rear flange to mate it up with your rear axle flange.
90B24wd
Big Island Hawaii
This is what 4x4junkie is saying: (DIY Cheep Rear D shaft) Also as for the rear flange you will have to find a flange that matches your rear axel. (7.5 or 8.8) On the front you need to beware that their is a fine spline and a coarse spline slip yoke. Only the coarse spline yoke will work with this shaft that I know of. And they come in different lengths. The longer slip yoke can be used for a shaft 31 1/4 or 3" longer. I am not sure if the shorter slip yoke can be used with the FM145 trans. I just made 4 of these shafts this past week.:icon_thumby: Shafts did not have to be cut shorter.
Not sure if my posted link will work? http://broncoii.org/forum/index.php?PHPSESSID=2b9b7663fffe6f7b0539c9b030863562&topic=926.msg7932#msg7932
You will find this front driveshaft on most broncos II's, rangers, and explorers with
a Dana 35 front axel. On the earlier Dana 35's some will not have this shaft.
ksum25
Apple Valley, CA
2.9 fuel injected sucide machine
I have a 88 BII that had the CV type driveshaft. I installed a 2" block in the rear and the driveshaft blew out just taking it around the block. I went to the junk yard and pulled a driveshaft off a 85 or so bronco II along with the yoke off the transfercase and it bolted up with no problems.
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
i'm going to guess your driveshaft was on it's way out to begin with
ksum25
Apple Valley, CA
Well the CV driveshaft held up but the boots are what went out causing a huge mess. Soon as I hit the first dip in the road I felt a pop and upon inspection the boots were torn from getting pinched. Being that it happend on the road I did not want to get stranded while out in the middle of nowhere so I went with a more common driveshaft just in case if I had to get parts from someone on the trail. I would rather change a u-joint than a CV boot.
85rx7_93ranger
Bemidji, MN
2.9
i have a rough country 4" with 33s and stock driveshafts are perfectly fine
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Do the cheap shaft build from the link above. Its what I di after my CV busted, then my double carden fell apart.
With 4" of lift:
tomisb
grants pass oregon
2.9L
You have two double cardan joints on your shaft? Wouldn't that make it flop around like a wet pig?
90B24wd
Big Island Hawaii
With 4" of lift:
The shaft that you are using is not the same shaft used in the "cheap shaft build". The carden joint is completely removed and only 2 u-joints is needed, one on each end.
disciplerocks
53
Evansville, IN
Try reading my post, not just look at the pretty pictures. The one on the left is the cv one. The one on the right is the double carden one I said went out on me. Thats why I built the cheapy rear shaft which is not pictured.
