- Aug 19, 2001
- Reaction score
- 583
- Location
- So. Calif (SFV)
- Make / Model
- Bronco II
- Engine Type
- 2.9 V6
- Engine Size
- 2.9L V6
- Manual
- 2WD / 4WD
- 4WD
- Tire Size
- 35x12.50R15
Use a double-cardan Explorer front driveshaft (the shaft will need to be shortened approx 2" if you have the M5OD, FM146 or A4LD trans in your '89).So will any explorer rear shaft work if I shorten it and put front flanges on it
You'll also need a front yoke off a 1354 t-case to put on the rear of yours, and a rear flange to mate it up with your rear axle flange.
