Thanks Bobby that makes a lot of sense.
Are you saying longer wheelbase is not as good for BOA? (about the Jeeps). Geometry question. I think I can visualize it.
What did you mean "leverage on the axles"?
I'm certainly not against bigger tires, but looking at the TRS charts, right away I get into problems with clearance.
Also unless I'm missing something, at some point I'd want/need to go to lower ration (4.10 probably) and that would be a major big job. Well, so would raising it enough to get bigger tires.
Although I'm not understanding why couldn't I go 4LO wouldn't that essentially be the same as lower ratio or am I missing something there.
In my very limited experience so far I have had no traction issues even with mild Cooper a/t's that are on there. I'll be getting new tires this summer/fall probably K02 or K03 31" that will raise truck about 1.5" (1" due to bigger [and oem] size tire, .5" due to tread wear of existing tires... I'm estimating. That's not a lot, but it's something. That would be oem setup.
What stopped me was 2 things (1) water - not horribly deep but enough to get on stuff that cools, can suck in water, so I'm addressing that (extent vent tubes). (2) breakover. you come up out of a creek even if there's no jagged obstacles (which there can be), you get the breakover issue. I probably would have been fine, and I suppose I'm kind of timid about scraping the bottom but I imagine sooner or later I'll find the limit.
Seems like, re the wheelbase, regular cab Ranger is shorter... but I really like supercab so I bought that.
It's true where I went (Broad Run road - there's vids - I linked it on my other thread on the vents) mostly what I saw was the really short Jeeps with big tires.
Not saying I'd never buy one but I really like Rangers.
I was told with LSD if it slips put on p-brake some and they should both get power so if I got in a tire spin situation for rear I'd try that before worrying about lockers.
I'm not against throwing some money at it, but first I'm doing the vents and tires, then get back out there. One thing that kind of bothers me is even if I went to say 33" that gains me only and inch of clearance over 31", that just doesn't seem like much. Going bigger, which you can do, the most you can gain is maybe 2" (with 35"). And then it's going to lose something for regular driving.
That said, I have the B3000 for in-town / highway driving, and, in general places I would want to off road are going to be within 50 miles of here. Also, the XLT was bought specifically for off use, it wasn't a necessity, more just for fun. I was up at the start of Broad Run with the Mazda and was like, oh-oh, I need/want 4x4 for this. I was going to sell the B3000 but now I find out it makes a lot of sense to have the two. Given the choice of a new Ranger at 43k or the '97 at a fraction of the cost, I figured it makes a lot more sense to go with the '97 and save the cash for upgrades. I'm just going at it kind of slow. I like the older truck I think they are cool and seem better/ruggeder and easier to work on and I wanted the front suspension type and etc it has. Point of all that is if you want to look at it that I "saved" like mid-30's money compared to new, I can spend some money on it. But there's a limit somewhere. Sure, I could get aftermarket fenders and go really big tires, put a big lift, lower the bumpers, etc but for what I want to do where is the point of diminishing returns. I'm not making a rock crawler (I don't think so anyway) and probably for easy-moderate trails I'm fine for now. When you get into extreme, no, for example Bald Mt or Potts Mt.
So for the moment - stock truck, but has one-piece driveshaft somebody put in, upgraded vents (soon), bigger (but oem) tires (soon), and I swapped the auto hubs for manual. Had to have one side drilled out $240 the key was put in upside down it was jammed in there they had to drill it out and cut the nut to get it apart. Guy that worked on it has two '97 Mountaineer 4x4 with 4.0L so, not the same truck, but, I think kind of similar, anyway, he knew what he was dealing with.
Can disconnect front sway to get a little more travel. Can air down if traction issues. So a few things I can do, although sway bar seems pita, would need quick disconnects of some type.
Please excuse kind of blathering on about it. One time I started looking at parts and wasn't hard to get to 10k but I'm not ready to pull the trigger on something like that yet, on the other hand, whatever I do, needs to make sense.
Attached pic (first one) of new ('23) Ranger I spec'd out, 43k easy, and looks basically the same as my truck and I don't think it's any better off road.
Also attached, baja setup, now I don't want baja, but it's cool looking as all get out, and you know those have ton of suspension travel and it looks pretty good clearance and should handle well on road as they go zooming around at high speed. A lot of money in the suspension, you have to change the steering etc and you see a lot of custom body stuff.
Last pic is probably closer to where I'm going it looks like probably some lift and bigger tires. I look at a ton of mod'd Rangers some don't look right. I think if it's done right it'll look right.
