regular bed vs stepside
fortek
South
None Yet
Is there a size difference between the stepside and regular bed?
Actually, can someone list the size of the different beds available?
Thanks
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
buddy, this is listed in the wrong forum. youll get a better responce if you move to styling and electrical-exterior
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Stepside is the same length as the regular, short (6 ft) bed. It is slightly less wide. There is also a long bed (7 ft), not available in step side.
skyy_4life
Brooklyn Ohio
2.3 turbo
yea my friend turned a fleetside into a step side. bolts are the same as long as its shortbed to begin with.
fortek
South
None Yet
I guess my main concern is can you fit a 4'x8' sheet of plywood (or whatever) into the bed? - I know it will hang off the end...
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
on a regular bed, they fit but it'll hit both wheel wells, that's what the notches for 2/6's are for...
fortek
South
None Yet
Now that's cool. I never saw those before. I guess there's 3, so a 4x8 will ride flat? I like it.
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
That would be a wide ranger, why would you want to do that ?
I would think the outside of the fenders would be about 3 or 4 inch outside the cab.
Yes you could still carry a 4x8 item, :icon_idea: interesting...
Please let me know your friends reasoning ?
Just asking... :headbang:
koda6966
61
The green part of NY.
2.9
I do believe he just swapped beds, not panels. If you want to see a panel swap look for Project Apple Bottom on this site, it's a member who is turning his Ranger into a Dually. He's putting the stepside bedsides onto a fleetside bed.
And to the OP, the only difference in size between a stepside bed and a fleetside/regular bed, is the width of both wheel wells on each side. A stepside has them on the outside of the bed, shrinking the width of the bed while a fleet side has them on the inside allowing the width of the bed to be larger.
