2.5L ('98-'01) Replaced injectors and Fuel Pump, Runs super rich and misfires
Kchorus
Sierra vista, AZ
2.5 (4 Cylinder)
Hello all, I've recently done some work to my truck, fuel pump, injectors, and fuel filter. I started the truck after priming the fuel and it started up perfectly fine and idled good, after about 30 seconds it started to slow down, then misfire, then nearly die. Now I'm just in this weird loop, no codes but multiple cylinder misfires. I've checked for vaccum leaks and found none so far. I unplug the IAC and the engine sits at about 200-400rpm and runs very quietly. I've also removed the fuel pump relay then started it and got my misfire, then it started to run right again minus the misfire as I revved it up. I'm confused and I don't want to shoot the parts cannon at it as that'll probably solve nothing.
BTW the injectors are standard motor products brand. They worked fine with the ancient fuel pump and I was able to drive. Then I installed the fuel pump and my problem arose.
Thanks!
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I see changed parts. Why? What about the air filter?
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
What year...
What engine...
SenorNoob
569
Middle Tennessee
245-70-R16
Can you check fuel pressure? I'm betting it drops off quickly when running.
Kchorus
Sierra vista, AZ
2.5 (4 Cylinder)
Fixed it. Put old injectors in, runs perfectly fine. Fuel pressure hold solid 60-70
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I haven't heard one single person say anything good about those injectors.
Kchorus
Sierra vista, AZ
2.5 (4 Cylinder)
Being returned as we speak. Old injectors were just fine :D
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Yeah... I bought a set of used factory injectors. I'm just gonna clean... test and rebuild them. Far better then aftermarket units.
No members online now.
