Rims and tires for bronco II?
Mcgoo
Lynchburg, TN
1990 Ford Bronc
2000 Ford Range
I have a 1990 Bronco II 2wd that's been lowered with drop I beams and hangers. I'm wanting wider rims on back than front. I found some on ebay that offer 7" for front and 8" for rear in 17". They have a 0 offset with 4" backspace for front with 215/50 tires. 4 1/2" backspace for rear with 245/45. Best I can figure this setup will be even with the outside lip of bronco. This will also give me 1 1/2" gap from tire to the body. Is this enough room for travel? I don't want to hit the body with the tire when I hit a bump. I did some measuring and have 27" from ground to wheelwell (body). I have 4 5/8" on front from mounting point on rotor to the outside of lip on fender (even with body). 27" height on rear and 5 3/16" from mounting point on drum to outside edge of lip (even with body). Any help on what size will work?
Mcgoo
Lynchburg, TN
1990 Ford Bronc
2000 Ford Range
Every wheel website says that 17x7 rims with a 0 offset will fit my bronco II but will these tuck?
Mcgoo
Lynchburg, TN
1990 Ford Bronc
2000 Ford Range
Wow 262 views and no help at all. I really was hoping for some advice here. I didn't expect this rom the Ranger Station.
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm surprised too. I can only suggest no one has tried what you're suggesting. If you do it, post up so someone else can learn from you.
