rollpan Questions
MSGia
124
Central Florida
4, 5
Good evening all, just had questions about rollpan bumpers. If I installed a steel rollpan onto my ranger, just bolt on not weld/molded in, would I be able to keep my factory hitch and spare tire?
If it matters, I have a SuperCab 2010 XLT with a 6ft bed, and this is the rollpan I would like to get. Also, while I'm here asking my question, is AirbagIt a legit site? Thanks all.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm sure it would leave the spare in place. The trailer hitch? I guess I would question why clean it all up with a roll pan only to have a big ugly trailer hitch hanging down.
MSGia
124
Central Florida
4, 5
Thanks for the reply, and I guess you're right, not like i'm gonna use a street truck for towing 😂 . I think I got the answer for my spare tire problem though, I think I have to ditch it, because the rollpan bolts up right over the spare tire access location. Probably good anyways bc my spare is almost scraping the ground.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I was thinking you could put a hole behind the licence plate and still run the spare up and down.
I will add that I've never put a roll pan on any of my trucks... so it's all a guess.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
i have seen that too. they have a fold down license plate where the hitch comes through at
MSGia
124
Central Florida
4, 5
Thanks for the replies, I don’t know if investing in a fold down hitch would be worth it for me for the 0 times a year I tow 😅, but I saw a rollpan design with a cutout for the spare tire access. I mean even if I bought one without a cutout notch I could just make a hole.
MSGia
124
Central Florida
4, 5
Is airbagIt a good site/vendor?
MSGia
124
Central Florida
4, 5
Some time has passed, thought I would update this thread in case anyone needs the info…
I could have kept the spare tire and the hitch. I ditched both of them anyways though. The spare tire carrier doesn’t stick out far enough to cause fitment issues, but I don’t have a spare tire anymore.
This is right, I didn’t think it would look that bad until I test fitted it. But if you wanted to keep it, it would fit.
Josh B
1,986
Oklahoma
I prefer the full size spare tire that will work in any wheel position, and sadly enough, it will not be accessible in 95% of the on the go situations where you will need an accessible spare.
The only accessible place I have for now is pushed under the toolbox
In order to haul a full load in the truck bed I must remove the toolbox and put the spare behind the seat :/
