Primosboy
- Feb 7, 2009
- 19
- Sacramento Ca.
- ford
- Engine Size
- 2.9 efi v6
Quick and easy roof rack build. Wanted a larger rack for overlanding and i did not want it to go on the stock cross bars. I don't like how high it would have sat off the roof. Did it all for free with spare material but I priced it out at $150. Hoops are made from 3/4 emt. Light weight but strong when you have enough contact points. Cross bars are imc which is slightly thicker but still lightweight. I used 1/4" plate for the uprights connecting the hoops. Probably little overkill but it's what I had lying around. Some heavy expanded metal for the bottom. That's the most expensive part. Home depot sells 4 packs of d rings I used to extra tie down points. The tricky part was the mounts. I used 6 pieces per foot using 1/8" bar and 1/4". Some light gauge steel for the logo that covers my crappy offset bends. Finished with rattle can bedliner. Rack sits about 2 inches off the roof and it's very strong. I can jump up and down on it no sweat.
