RX8 Build Thread
3,614
Little update:
The car is in the shop. 1 bad coil, clogged cat and failed compression test.
Well you will get that with those rotary engines. I am not sure who thought an engine with only one moving part was a good idea.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
Did you have to replace/rebuild the motor?
SVT
The cat was choking the motor. It runs better but it is not 100%. I think it has a misfire which means all new coils, plugs and wires. I am also going to clean the grounds just to be safe.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
I have 2 rotors so that is 2 moving parts. :icon_thumby:
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
Actually you are all wrong. There are three moving parts. 2 rotors and the crank shaft.
Sent from my rooted SPH-D710 using Tapatalk 2
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Doesn't the driver move when he shifts gears or uses the brake or gas pedal? I'd hate to sit still while driving because I drive quite a bit.
Nice looking car...I remember when the RX series came out many years ago and I wanted one...but everyone said to wait until they worked out the bugs in the engine...lol
3,614
Eh, whatever. I never worked on one of them Wanker engines. I'm not even all that sure how they work. Doubt I could diag one if it landed in front of me.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
I love my rotary.
3,614
They're extremely simple...
I understand the principles that they work on. I know that on paper they are simpler than a normal engine. I just don't have any experience on them.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
I've heard they don't have a rev limit. I had a buddy that had an 89. Mostly stock, had it riced out with an aftermarket tach. Installed nos on it went for a ride with him, at about 7k rpm he said watch this, and hit the nos, the tach literally hit the bottom of the gauge and the needle bounced off the bottom. It was kind of funny...
SVT
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
I try to shift between 5-6k; however, I can on it all the way up to 9500 RPM before I have to shift.
UPDATE:
Motor is gone. So I traded my F4i for the motor plus install. It is freshly built. I am losing money on the deal; however, you have to do what you have to do to get shyt done.
dangerranger83
54
Lafayette, IN
Put a 4.6 under the hood.
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
UPDATE:
Well....it is what it is
Sent from my HTC VLE_U using Tapatalk 4
3,614
Pffff. Don't make me laugh. If he is going to go to the trouble of a V8 swap he should do the S/C 5.4L GT500 engine.
dangerranger83
54
Lafayette, IN
Better yet a boosted 2.3
No members online now.
