snorkel diy/kit
Kyler Skovbo
oregon
ford ranger
I recently hydro locked my motor and before I take it back offroad and through water I want to find or make a snorkel for the truck. It is a 1991 with a 2.9 motor, the only issue Im having is I cant run the pipes out the passenger side because of other modifications. does anybody know of a kit that I can modify or have tips on making their own?
8,370
Well how high do you need the snorkel to be?
You have a mechanic fan and a distributor
Cab high snorkel would look cool but engine would still stall with 6" under hood high water
Maybe a hood scoop facing back toward the cab
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
I ordered tubing and couplers from EBay or Amazon, plus a different filter housing from the junk yard and cobbled together my own design.
NMC_EXP
40
Raton, NM
If you will drive thru water also install extended vent tubes on your differentials (and maybe transfer case?) to get them above the waterline.
Differentials build pressure in operation. That is due to how Extreme Pressure gear lube works - that is that skunky sulfer smell you get. So differentials have a pressure relief valve on them to dump the pressure so as not to blow out the seals.
Drive thru cool water and the diff. may decide to inhale rather than exhale. End result it sucks in water. Not good.
I had a new '79 FJ40 Toyota Landcruiser. Drove thru a creek maybe 2 feet deep. Next time I checked the fluid level in the diffs it was milky white meaning water contamination.
A PO had installed extended diff breather tubes on my FJ60. The front ends up high in the engine bay. The rear is high in a rear inner fender.
If you're gonna drive thru water, extend those diff breathers up high.
Jim
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
And where they wont get sprayed from the tires
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Though I've been late doing it, yeah, breather tube extensions. Rear diff to go probably by fuel fill hose, front, I have xfr case, trans (iauto), and front diff, they can all go up in the engine bay. For manual trans breather is at bottom of shifter I think so no breather for them. Manual xfr case probably does have breather, I dunno. Doesn't cost much to do and worth it.
