So I Ordered 4 Tires from Walmart Online. But there all being delivered separately on different dates 😠
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
If you wanna stretch every last mile out of those tires as you can.. chaulk test.
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Sometimes you eat the bear, sometimes the bear eats you.
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
What's the chaulk test? I'm not familiar with that.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Take some sidewalk chalk and coat the tread of the tire. Roll the truck and see what gets rubbed off and what doesn’t. The tread should make full contact across the entire width of the tread.
Typically, the best psi is pretty close to the OEM one(s) on the door jam sticker.
My OEM tires were 35 psi. When I ran the math on the new tires, I came up with 36 psi to meet or slightly exceed what Ford had the original tires setup as far as load capacity.
Lefty
1,847
Saint Paul, MN
Ranger Edge
You may do good with uprated sway bars too. They reduce body roll which, in turn, saves the edges on the tires, especially on the front end.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
The tires have a 50psi, so... They put in 50lbs but it rode too hard. So I brought it down to 44. Ride is better.
Ouch. Why so high? It would be advisable to use the pressures listed on the door jamb sticker. Probably between 32-35psi. Got a truck as light as an old Ranger, even 32 is pretty high when unloaded.
ericbphoto
16,598
Wellford, SC
6"
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
Can you send me a link?
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
It says 50 psi on the actual tire.
Angry Possum
Law Enforcement
473
Staten Island NY
Ranger XLT SC
4.0 OHV
N/A
N/A
I am getting some light scraping in the front tires when turning hard. I guess I can add the updated sway bars like @Lefty a forum member just stated. Does anyone have a link for these sway bars, and are they easy to install?
fastpakr
2,834
Roanoke, VA
Lefty
1,847
Saint Paul, MN
Ranger Edge
You can pull one out of a junkyard. Get one from an Explorer which is the same year as your truck. Or go on Ebay. You want one that is 1" thick, probably from a v8. You will also need new link pins. If you have never done it, ask a friend to help
Lefty
1,847
Saint Paul, MN
Ranger Edge
If your ranger has torsion bars then you can crank them a little tighter and lift the front end until the tires clear the fenders.
alwaysFlOoReD
5,098
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The pressure as written on the tire is not what is recommended for your particular vehicle. Somewhere on your vehicle, glovebox or door jamb are common spots, will have the "correct" OEM pressure listed.
2011Supercab
467
Washington
Toyota Tacoma
Use this calculator to find the correct pressure when you change tire size.
