stuck intake manifold
rangerrobee
washington
ford ranger
i cant get the upper intake manifold off, ive unbolted all 6 bolts and everything and its still stuck solid, 4.0 v6 ohv please help
  • Like
Reactions: gaz
rusty ol ranger
2.9 Mafia-Don
7,632
Michigan
177 CID
Might need to take a rubber mallet and pop the top of the intake (side to side) a few times. If youre sure you got all the bolts its probably the gasket glueing it down
gaz
672
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
@rangerrobee ,
Is your 94 an EGR engine? If so, you will need to also disconnect the EGR valve from the upper intake manifold.
superj
2,671
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
hit it with a hammer
SenorNoob
589
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
gaz is right. But (rubber) hammer it, if you're sure there is nothing else holding it on.
