stuck intake manifold
rangerrobee
washington
ford ranger
i cant get the upper intake manifold off, ive unbolted all 6 bolts and everything and its still stuck solid, 4.0 v6 ohv please help
  • Like
Reactions: gaz
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
Might need to take a rubber mallet and pop the top of the intake (side to side) a few times. If youre sure you got all the bolts its probably the gasket glueing it down
gaz
657
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
@rangerrobee ,
Is your 94 an EGR engine? If so, you will need to also disconnect the EGR valve from the upper intake manifold.
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
hit it with a hammer
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
gaz is right. But (rubber) hammer it, if you're sure there is nothing else holding it on.
No members online now.
