Swap engines, need timing done still?
Final777
14
28159
I
Okay my mechanic told my the head was seeping on my 89. But it's never run hot until the other day when it started smoking inside the cab (not from the engine bay), which led me to believe that the smoke was coming from the heater core. So of course I bypassed it. It's no longer smoking in the cab, but before that happened the engine temperature gauge never even got past the cold on the gauge.. but since that happened, it stays in the normal part. But I would think if the head was seeping then it would have run hot, but it never did. Something is obviously wrong because I lose a lot of power around 4th gear, lose a great deal of speed and momentum going up hill. If I take the valve cover off should I be able to tell once I'm in there if something like that is wrong with it,? Obviously if I see a crack somewhere I'll be able to notice, but the very same y thing happened to my 86, and it never ran hot, the only difference was that in my 86 the motor would shake vigorously while at idle but she would smooth out once I pushed the accelerater but same exact thing, I would lose a lot of momentum to him and she didn't want to go even if I had my foot to the floor. I took that engine out but couldn't ever find a crack in the head or anything like that. I'm trying to learn all I can so any advice or pointers that y'all give me i will surely listen, ty so much, you guys have been a great help!! And also, does the engine required to still be put into time even I left it on tdc when I removed the engine ty!!
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
Is this a 2.9?
Final777
14
28159
