The elusive 7/8 bore master
Junglejoe
66
Columbia Missouri
6.0
Hmmm.. I know a couple guys who run the hydraulic throwout bearing, not sure if the one mentioned here but they said it works perfect. Stock ranger master. I used the f550 master and external 280z slave on the black truck, it "works" but you will not be doing ANY hard driving. That setup will not work for that.
Mr_Lee
Windham Centre, Ontario, Canada
Ford Ranger XLT
L33 5.3 LS
5"
245/45zr17 & 275/40zr17
I have a Tilton hydraulic slave behind a L33 5.3 LS and TR-3550. I cannot get the clutch to disengage. There is not enough travel, its good to know that someone else has gotten a Tilton and TKO to work on a Ranger. I guess I have air still in the system or its out of adjustment. Although by the looked of it threw the clutch fork window in the bell-housing its in the right position. I have a 2000 Ranger so that might come into play. Maby I'm not getting enough travel because my pedals are designed for a 95+ Master Cylinder.
smilinjack
34
rochester, mi
ford ranger
408C
2"
Always bite off more than you can chew!! :)
I'm not using an internal slave but I too needed the large bore master cyl. on my toploader 4 spd. I went with the F550 Super Duty master/slave kit. I did not use the slave cyl., but did use the master cyl. and It worked just fine for me. I'll bet I spent a month looking for that master! Hope this helps , Good Luck !
Mr_Lee
Ford Ranger XLT
L33 5.3 LS
5"
I bought a F550 Master and new pedals. I wanna try getting it working first before I swap everything out since a member whom posted here has the same setup as me in his 1988 Ranger. Maby he can shed some light on my situation.
