Transmission Swap Help
So I have a 1990 Ford Ranger with a 2.9l V6 and a FM132 transmission currently bolted to it. Truck is 2-wheel drive, but the tranny is shot. I have an M5OD-R1 from a 1991 3.0l Ranger and am curious if the swap is possible. The yoke on the old drive shaft shaft is slightly too small to fit the newer transmission, so would a yoke from a driveshaft off of a 3.0 motor match the U-joint? Also, would the starter from from the same 3.0 motor work on the existing flywheel from the 2.9l? Still haven't checked if the tranny will even bolt up, just looking to see what is possible wit what I have already.
8,370
No, the 2.9l and 3.0l bell housing bolt pattern won't match
M5OD-R1 bell housing doesn't come off.
2.9l and 4.0l used the same bolt pattern
Maybe you can find a trade for 4.0l 2WD for your 3.0l 2WD
Needs to be 1997 or older, so it will have speedometer cable hook up
You will still need different drive shaft
Would a 5-speed from a 2.8l Bronco match?
Awesome thanks for the help, I went to pick a part today and found a Bronco 2 with a 2.9l and 5 speed on it, but it is 4WD. Could I used the transmission without the transfer case for my 2WD with some modification to the rear of the tranny? Or is the output shaft too different?
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Very different.
2WD Explorers seem to be all over the place (at least around my neck of the woods they are). Might be another option to look for.
8,370
Manuals in explorers are hard to come by, and would need to be '91-'97 4.0l M5OD-R1 to get the speedo hookup
FM132 was 2WD only
FM145 and 146 were the 4WD manuals used before the M5OD-R1, and they had no separate tail shaft to swap out to convert to 2WD
