Weird lever
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
6-7” front maybe 3” rear
33x12.50-15
Anyone know what this lever is for? It’s in an ‘89
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Not sure I've ever seen that one...
Maybe a fuel door release?
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Engages the neutomium quantum drive for ludicrous speed.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
That releases the fuse box, pull that then rotate the fuse box down that is just behind it...
RobbieD
2.9l Mafia
3,465
Georgia
Optional ejection seats.
Seriously, like Scott says it'll let you swing down the fuse box.
ericbphoto
16,598
Wellford, SC
6"
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
That sounds handy. Why don't we all have that?
I thought all the '89-94 dash had that? Your '93 doesn't? is it one of the things they changed in mid '92?
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
Must be because my 94 doesn't have it.
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
Mine doesn’t have it either. Wonder if it’s the same box.
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
Sure enough..
RobbieD
2.9l Mafia
3,465
Georgia
I'm glad that it wasn't the ejection seat.
I don't know for sure the what or why for the dropping fuse box being different from 1989 to 1994.
Even though the same basic dash design was used '89 tp '94, I'm guessing that the big change in the electrical wiring occurred with the move of the EEC from the passenger kick panel thru '92 to being underhood on the firewall starting with the '93's.
ericbphoto
16,598
Wellford, SC
6"
I need to watch for that assembly in the junk yard. Getting too old to always be twisting upside-down under the dash just to look at fuses.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I've owned several trucks in that year range and never saw that lever in any of them.
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
I still have to pull the dash but I suppose for the time being, I can check fuse locations between the ‘89 and my ‘94. If a guy was ambitious enough, he could probably re-pin the fuse panel to work in a newer truck.
Edit: I’m dumb. Just use the bracket if possible. I’ll pull the dash out tomorrow to take a closer look.
RobbieD
2.9l Mafia
3,465
Georgia
The drop box is in my '90 B2, but not in the '94 Ranger or my '94 Explores. Can't remember on the other 1989-92 years' that I've had in the past.
Can't you just get an app for that? Or don't they make fuse drones nowadays?
