What are the specs of the thermal fuse in the blower motor resistor?
kxri318
28
Ohio
The fan was only working on high in my 1986 Ford Ranger and I read that it could be caused by the resistor itself or corrosion in the connectors. I checked all the connections and they're all 100% corrosion free, so I tested the actual thermal fuse on the resistor itself and the fuse is blown. Does anyone know the specs of this fuse? There are 0 marking on it at all, its just solid black.
franklin2
1,758
Virginia
This link says 121 degrees C for the value.
kxri318
28
Ohio
Yeah I saw that too but that's for a 98 explorer. Wasn't sure if mine was slightly different or not.
franklin2
1,758
Virginia
I have done several where I just used a jumper. I do not know the purpose of them, I have seen many stories of the resistors catching leaves in the heater box on fire and melting it. The thermal fuse did not do anything to prevent that.
CamTheHedgehog
ASE Certified Tech
313
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
If only our trucks had cabin air filters.... every spring I have to pull my blower motor out and clean the leaves out of the housing. That noise of the leaf rubbing on the fan blade drives me INSANE.
franklin2
1,758
Virginia
The resistor is downstream of the fan were the airflow from the fan keeps the resistor cool, it gets red hot in normal operation. When the leaves enter and are still flexible, they can make there way down onto the resistor and hopefully it will just smoke you out of the cab. The worst case it catches fire.
8,370
120degC is 250degF and its not a "fuse" but will melt and separate like a fuse if it gets hotter than 250degF
These "blow"/separate based on temp only not AMPs
Regular fuse "blows" based on AMPs and temp
Yes, 120degC would be correct for these in pretty much any year Ford
Josh B
1,986
Oklahoma
A friend had a 94 that caught fire and burned. Not long after I was headed to town and turned on the heater/defroster and soon smoke was coining out my vents.
I shut that thing plum off and luckily it didn't go any further. Soon as I got home I cleaned all the duct work, and also put screen wire across any openings anything could get through, inside and out
kxri318
28
Ohio
I bought a pack of 121c thermal fuses for a couple bucks and put one in. It works great now on all speeds, thanks a ton.
kxri318
28
Ohio
When I removed my AC (previous owner mangled it) and threw in non-ac air ducting, it was completely packed full of leaves and honestly I was surprised it hadn't caught fire yet. Good to know that's something I should check more often though
