4.0blue98
I don't feel tardy...
708
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Changed oil. Noticed rear main seal is leaking more than usual. Front crank seal leaking a little and coolant leaking from WP weep hole. Fortunately I have a WP in stock. She's getting tired...
Now where did I put that "easy button"?
CamTheHedgehog
ASE Certified Tech
431
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
Replaced the front crankshaft seal yesterday, took me about an hour and a half. As expected, the hardest part was the bolt. The old seal came out incredibly easily, and it was clear it was also leaking around the seal between it and the housing bore. The new one is significantly more tight in the bore, more than snug to feel confident about it unlike last time.
I started off using a 38mm axle nut socket to drive in the new seal, but it a) limited the amount of room I had to swing the hammer, and b) ended up cocking the seal in the bore anyway.
I changed to a short pin punch, working my way around the seal and double checking with the depth gauge on my calipers as I went. The seal from factory, as well as the first replacement, were recessed about 9mm in to the housing. On this one, I recessed it to 11mm, shifting where it would wear on the balancer. I also made sure to apply silicone inside the balancer where it meets the crank snout, per the repair manual; as well as lubing the seal with a bit of grease.
Finished things up on top, then went to town with brake cleaner and a rag to remove all the evidence of an oil leak.
Today I look under my truck..... and it appears to be leaking again. What did I do wrong? Did me using the pin punch damage the seal somehow despite my carefulness? Do I need to buy the special seal driver tool ford specs in the repair manual? Do I need to remove, reseal, and re-align the timing cover? Anything is appreciated, I'm getting ticked with this leak.
Bgunner
1,117
Western Mass.
Ford/Ranger XLT
225/70/R15
First you need to find exactly where it is leaking. Is it front the crank snout or the between the seal and timing cover?
A little RTV on the outside of the seal will help it seal to the timing cover to prevent leakage from there.
CamTheHedgehog
ASE Certified Tech
431
Charlotte, NC
Ranger Edge
4.0 SOHC
Yeah, that's the one thing I didn't do and probably should have. Off to the dealer to buy another seal and bolt.
JoshT
1,908
Macon/Fort Valley, GA
Failed on charging the AC system and finally really drove it for the first time with the V8.
As I mentioned yesterday, we were trying to charge the AC sustem that I thought worked in the explorer before it was disassembled. The rental vacuum pump from O'Reilly wasn't up to par and would only pull around 16" of vacuum. Purchased a much larger (3 vs 1.8 CFM) two stage vacuum pump from harbor freight this morning. That thing works. Pulled the system down to 30 inches almost instantly. Let it run for the recommended two hours. Unfortunately trying to charge it revealed that the compressor isn't working. Compressor clutch works, we jumped it and it engaged, but built no system pressure. Going to take a break and drive the truck for a few weeks before taking it back apart to fic AC. In the mean time I have to decide if I'm going to re-use parts from the previous (working) 4.0L AC system or buy all new Explorer 5.0L components. I just bought the receiver drier and orifice tube so they should be good. Both evaporators should be ok since the orifice filter would catch any debris, just flush it. The compressor and condenser are the questions. Compressor is the same except pulley size is different, but those can be swapped. Condensers mount different, the 5.0 to the radiator and the 4.0 to the core support. If it fits with the 5.0L raiator, the 4.0 condenser would be easier when/if I need to work on the cooling system in the future. I might start another thread on this.
After figuring out the AC was a bust and pulling the compressor relay, I took it for it's second maiden voyage up the interstate. Second because I did drive it up the interstate to the exhaust shop, but still maiden since it wasn't running right due to plug wires being wrong and got towed back. Ran great, but I expect it to get better as the system learns. Hopefully the transmission will learn some too. It shifts well, but I feel like it could be better. Might just have to get a tuner and adjusted shift points after I get a few miles on it. I imagine a shift kit would help as well, but not sure I want to touch the internals on a relatively unknown transmission.
Drove truck home tonight and it will be my daily for the next few days (weeks?) unless something happens. Might take it to my mechanic buddy later this week and complain about the noise and feeling different without mentioning the swap. He doesn;t know I started the swap, but knows me and will figure it out quickly. Also probabaly give me crap for not fixing a few things while I was in there.
lil_Blue_Ford
6,328
Butler, PA, USSA
4.9L
@JoshT , I don’t have my AC done in mine either. I need a hose and probably a compressor. Think I might just replace my evaporator too. Got a new receiver/dryer and orifice tube ready to go for it. I’ll have to get on fixing it though.
As for the transmission, yeah, it’s sloppy. No external adjustments for the bands either. Mine has been happier since I changed the tire size in the computer and it tends to shift better if you’re a little less than full throttle. I’ve been looking at shift kits and valve body stuff. Probably gonna happen before long.
JoshT
1,908
I drove to work and around town today. I learned a few things about the V8 swap from it. More on that below.
Being here in middle Georgia, the AC will be fixed by the end of April. Even if I have to throw the parts catalog at it, it will be fixed by then. We're going to run through the charging procedure again sometime this week just to make sure that we didn't do something wrong. If that fails I'll either be cobbling parts from the 4.0L system or buying a new compressor and condenser. The system on the 4.0L was working when I started trearing the truck down a few weeks ago and I removed the system intact without opening any lines. I'll have to carry it to get the Freon recovered, but all the components should be good. Will have to swap the compressor clutch, but other than that I could use those parts.
Transmission will get something, but I need to put some miles on it before I'm willing to sink the moneyt into THIS transmission. It needs to prove itself for a bit. If it shows signs of failing, I'll do that work on a replacement to swap in. I knew from the start that this transmission failing in short order was a possibility. No alarm bells, just a used and unknown part.
My first move towards improving tranmission will probably be through tuning rather than a shift kit. I say that because one of the things I figure out today (other than just confirming the sloppy shifting) is that the explorer was apparently speedlimited at 90 MPH. Not that I need to (or will regularly) run 90, but it should be able to exceed that easily and there were still people passing me that speed. Sunday on the interstate I wasn't sure if it was just breaking up at those speeds, it felt like it was pulling hard until it just wasn't. I hit a "closed course" on the way to work this morning and it is most definitely in the tuning, repeated it on the way home. Either fuel or ignition gets cut almost as soon as the needle hits 90. That has got to go away soon, so I'm going to be loking into tuning options.
Another thing I figured out is that with AWD the V8 is deceptively strong. With the 4.0L it would let you know when you hit the throttle too hard. Even if it didn't break the tires loose you could feel the launch. With the AWD it just goes. It doesn't feel like a particularly hard launch even if it is harder than with the V6, it just goes. Aside from the lazy shifting, which I hope will improve some through learning, it just keeps pulling. Well, it just keeps pulling... until it hits the speedlimiter.
Finally, I figured out that this exhaust is not a long term solution. It does work and makes the truck quiter than the pipes open behind the cats, but it's louder in the cab than I wanted and I don't know that I care for the flowmaster sound. I wanted a dual in/out turbo muffler, but shop "couldn't" fit what I wanted. I'll probably end up with two single in/out turbos and a crossover if I can't find a shop to use what I wanted. I can live with it until I get the suspension sorted. In the mean time I might see if I can attach the original tail pipe in palce of the turndown that they put on, assuming that it is the right size. That should move the sound further from the cabin and out froom under the truck.
38
Olympia, WA
Mazda B4000
33’
Took the rig up to the trails today. Being in Washington in early spring means a whole lot of rain and with that comes a whole lot of mud. My buddy came with in his Jeep and we did about 35 miles most of which was at pretty high elevations, but in the low altitude spots the rain was collecting a lot in spots and made some pretty tall water crossings. We got through unscathed though. I broke my air filter support though, so it was annoyingly slamming around under the hood for the last five or six miles, but that’s what I get for buying a cheap chinese eBay air filter tube. All in all the truck held up great and didn’t have one issue with idle or running rough like the problems I’ve had the past couple weeks.
lil_Blue_Ford
6,328
Butler, PA, USSA
4.9L
@JoshT
I need to finish lowering my front end before dealing with the speed limiter. But yeah, the speed limiter has to go. I’m not sure if it requires a tuner or if there’s a way to do it with Forscan. Haven’t dug that far into it yet.
I’m really tired of the sloppy shifting. It needs a shift kit. Early on I was worried about the condition of the transmission because it acted up a bit, but they don’t like sitting and it was sitting awhile. After putting a couple hundred miles on it, the only thing it does is the sloppy shifts. I’m irritated enough that as soon as we start getting more consistent decent weather, I’m probably gonna get it done.
Mine launches nice. I need to find the other traction bar bolt and get those in, I can feel it try to rock back a little on a harder launch. I try to roll into launches though because I’ve been told there’s something in the transmission that slides and bangs hard on hard launches and the better shift kits eliminate that by starting in second for like one turn of the tires. The AWD does make a huge difference in being able to fully utilize the power of the 5.0. I’ve had a few people tell me that my truck is junk because I can’t smoke the tires. That’s nice, you sit here and smoke your tires and think you’re cool but I’m gonna be waaayyy over there because my toy is gonna hook n book. The AWD is a game changer. It will try to fight you a little in hard cornering in the steering wheel. I’ve been debating going to an electric power steering pump which would deaden that. Part of that problem though is space under the hood to make it happen. It would have to go where my air box is or I’d have to run long lines and mount it under the bed.
My recommendation on exhaust is a Magnaflow crossover muffler. Here is what I’m running and what dad’s had.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,934
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
@JoshT
Some people see benefit on burning rubber for some reason. I'd rather keep the rubber gripping the pavement and get moving faster.
lil_Blue_Ford
6,328
Butler, PA, USSA
4.9L
Yeah, seems like a lot of people think that burning rubber means your vehicle is cool and fast and also they usually think the louder your vehicle the better. I think those people are a bit daft. If you can light up the back tires, especially both and not just one (or front tires if it’s a front wheel drive vehicle), you have a traction problem because you’ve just proven that you can’t effectively and efficiently put the power your vehicle produces to the ground. It’s also a good way to break things and ruin tires, none of which is cheap. Every ounce of power my 5.0 AWD Ranger makes I can effectively use right now between the AWD and the packed limited slip rear. When it was in stock form with an open rear, 4x4 and 4.0, I could do a one wheel peel, often accidentally, which irritated me to no end when I was trying to hurry up and get going. Same with why my F-150 has a rear locker. Smoking a tire off when you’re trying to hurry up and move is not productive. I want to hook n book, not play around.
CamTheHedgehog
ASE Certified Tech
431
Charlotte, NC
Ranger Edge
4.0 SOHC
@lil_Blue_Ford and @JoshT
What do you guys mean by AWD? I thought the explorers/rangers only came in 4x4 or 2wd, as a full time AWD system requires a center diff or viscous clutch.
CamTheHedgehog
ASE Certified Tech
431
Charlotte, NC
Ranger Edge
4.0 SOHC
Also, @lil_Blue_Ford, I try to avoid hard launches for the same reason- the trans. Any recommendations for "good" shift kits that will let me ham on it without fear of excessive wear or damage?
ben_2_go
381
Third rock from sun
Furd
2.5 (4 Cylinder)
2.5 Scrap
235-75-R15
None at all.
Some of the limited edition Explorers and Mercury Mountaineers came with AWD. I believe some had a low range. Yes, they had something like an open diff inside the transfer case, from what I can remember. They weren't very reliable and a lot of them ended up getting swapped for a standard t case. Very limited numbers of those were made.
Here some info. Very little info, but it's in there.
snoranger
Professional money waster
ASE Certified Tech
13,776
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The 95-01 V8 Explorers came in either 2wd or AWD. None of them came in 4WD of had low range.
The AWD t-case had a viscous coupler that allowed for the slip between the front and rear. They were known to go back from mis-matched tires. Even a worn out tire or 2 could cause issues over time. When they went bad, a common symptom was that the vehicle could drift in park.
That’s enough Explorer facts for now… if there are any other questions, just ask.
