CamTheHedgehog
ASE Certified Tech
313
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
Thanks for the info, both of you! Useful to know if I (someday hopefully) do a V8 swap.
lil_Blue_Ford
6,131
Butler, PA, USSA
4.9L
@lil_Blue_Ford and @JoshT
What do you guys mean by AWD? I thought the explorers/rangers only came in 4x4 or 2wd, as a full time AWD system requires a center diff or viscous clutch.
Just that, the 5.0 Explorers and Mountaineers were either 2wd or had a single speed AWD t-case. The AWD case isn’t really good for off-road use, but it works well on the street. Since I lowered my green Ranger, it’s not going to see much more than a dirt road. If I want to play in the dirt, I have my Choptop and F-150 for that. Green Ranger is a straight up street toy for me.
Also, @lil_Blue_Ford, I try to avoid hard launches for the same reason- the trans. Any recommendations for "good" shift kits that will let me ham on it without fear of excessive wear or damage?
I’m not sure it’s a problem for any other transmission but the 4R70 and AOD/AODE. Just a problem I noticed references to in those transmissions because that transmission series was behind 302 engines in police cars and taxis (think crown Vic). So they were subjected to a lot of abnormal abuse and a problem was found. Not that I hammer on it all the time or anything, but it’s a noted problem with the transmission behind the 5.0/302
As for a good shift kit, I’m not really sure what is available for your transmission. The only shift kit I’ve done so far was in my red 92 Ranger and I did the recommended TransGo kit with some other recommended additional parts and it was 1,000x better than a stock A4LD slushbox. That truck despite a working rear limited slip would light up the back tires just by giving it too much gas from a stop. At the time I did the work, there were only two kits offered for that transmission but now I’m hearing there may be another option.
Manscout
122
Gillette, Wy
33x12.5x15
I am a big believer in pics with posting. I'm a part of multiple forums and I find the folks that care the most use them in their posts. That's not an indictment on anyone here, but it really adds to the enjoyment of being a forum member. There is a saying about what a picture is worth. Sometimes you just have folks that would rather type up the 1000 words. :LOL:
What I finally did TO my Ranger:
- Finished up my pillar pod holder. I'm using a Glowshift Vac/boost gauge on top for the supercharger and testing a dual temp digital on the bottom. I am not loving the temp gauge. Sometimes it bounces wildly +/- 5deg. The top is to a sensor near the grill, and the bottom is the interior temp near the footwell. The night mode is still ridiculously bright too. The Glowshift is perfect.
- I got my TRS decal on the window! Looks good! Thanks Jim!
17,848
SW Iowa
Since I am not really to the point of hooking the winch up yet and the cables were just kind of wrapped around the winch I slipped the winch back off. No idea when but the Ranger is going to be pulling dd duty for a bit while my dd is in the shop. @Mrs. Eighty Five was sitting at a stoplight in Omaha with 85_Ranger4x4jr in the back seat and somebody did not see the Aluminum Falcon sitting there... and took a 2" ball to the grille. AFAIK so far nobody got hurt, sounds like it was a pretty good bump though.
CamTheHedgehog
ASE Certified Tech
313
Charlotte, NC
Ranger Edge
4.0 SOHC
Do you have the grab handle on your pillar? I want to do this to my ranger for oil press. and water temp, but I have the “oh crap” handle in the way and I don’t know if the glow shift double pod will fit under it…
rubydist
858
Denver
Ford Ranger FX4
I can tell you that the dual pod does not fit with the "oh crap" handle on - I had to remove it to put my dual pod housing on. And, I still mounted it too low. If you put it down too low, it blocks the airflow from the vent on the end of the dash that is supposed to keep the driver's window from fogging up, so you can see the driver's outside mirror. The way I have mine, the airflow is partly blocked and it does not do a good job of keeping the window clear. fyi, I have a boost/vacuum gauge and a air/fuel gauge in mine.
I think there was some GM truck that had a "oh crap" strap that just attached with one screw. I've been looking for one during my jy trips, but have not yet found one. If I find one, I will install it on the one screw location that is still available.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I put the same pod on my truck... I was mindful of the vent but it still isn't big enough to cover both grab handle mounts. I opted for a volt meter and oil pressure. The glowshift gauges match close enough when sitting with key off. When running... the dimmable LED lights are really too bright. But I'm living with it.
Rick W
3,901
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
If it helps, I put a few JC bars in all three trucks for sweet pea to get in and out. One overhead and one on the A pillar. My 87, 96 250 and 97 didn’t have them. In the 87:
Obviously these weren’t Ranger grabs from any year. The column was a Ford, and the little one overhead was from a square body Town Car, which coincidentally, fit the Missing Linc theme. They’re just put in with self drilling/self tapping hex heads, which is pretty much the way Ford put them in anyway. I can hang off all of them, and I’m a little bit bigger than sweet pea.
Point being, if you look around the pull a part, you can probably find a handle that works and you can still put the column gauges on. I mean no criticism, but if I had to grab it, I would want more than one screw in it. Might have to drill a couple more holes, but it’s plenty strong to take all of it.
My two cents, hope it helps
JoshT
1,734
Macon/Fort Valley, GA
I feel like I'm being targeted here and take offense. :flipoff:
:icon_rofl:
Some of us just ain't good with cameras, besides if I stopped to take pics every 5 minutes I'd never get anything done. Maybe if I were working in my own shop, I'd take a little more time to get some pictures.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
I take pics but I don't always post them... combination of when I plug my phone into the computer Winamp wigs out (yes, still use it, it's still a thing...) and my one unit of internets makes things annoying, and I get distracted easy... :) That and I type fast...
bhgl
160
Northern Ontario, Canada
Mazda B3000
Rolled MAB3L over to 80 000KMs today on a quick 8 hour road trip to find some elusive thin tires.
Got compliments for driving a regular cab, short bed truck by a nice fellow with a late 80s Chevy C/K, with a reg cab and short bed.
ekrampitzjr
1,067
Virginia
This fluctuation is normal in most vehicles, which is why the factory temperature gauge is damped to keep the needle in one spot near the middle between C and H at normal running temperatures.
Manscout
122
Gillette, Wy
33x12.5x15
I'll reply since you asked me on my post, but it's the same as others have said. I don't have that handle anymore. It covers the lower mounting point. It's not a huge deal for me.
Manscout
122
Gillette, Wy
33x12.5x15
Thankfully, I don't live in an area where window fogging really happens.
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
Well I went out to see if the Beer Fetcher would start knowing that it has sat for over 3 months. I got exactly what I was expecting, No lights in the cab and no lights with the ignition turned to run so I put the good ole electronic battery charger on it and low and be hold it had some juice... 6.8 volts worth of juice. I left the charger on it set to 2A and went inside for about an hour and a half and went to check on it. Bad Bat... or so the the charger read. I remember a day when a battery charger would actually charge a dead battery, I'm keeping my eyes open for an old charger. I unplugged and plugged it back in again but set to to the BOIL setting (12A) this time and went in for a half hour. When I went back out the charger was still going this time so I adjusted the battery clamps and charger so I could set the hood down knowing it's going to need all night to charge. A few hours later my friend stopped by so while I was out there I lowered it to the 2A trickle charge setting for over night cooking. A slow charge is better than a fast one so that is where I'm at on that.
I did talk to my friend about getting the Beer Fetcher into his shop to get the timing chain and cover done so progress has been made on that front. He has a lift and the shop is in walking distance of an O'Reilly's incase that thing that pops up that wasn't planned for inevitably pops up.
Added coolant to the overflow as it was low also.
I probably should have put the charger on it when I got home but life just had me down and I needed some time to get my head right.
Tomorrow the Beer Fetcher will be back at work getting me them beers.
No members online now.
