Whats involved in front fender removal?
Airmaster
South Florida
2013
Mazda,
Chevy
3.0L Stick, 3.6L Stick
Hey guys, I'm wanting to beat out a dent I have on my left front fender and it seems the only way to get behind it is to remove the fender.
What exactly is involved in taking the fender off, it looks like a lot of stuff is attached to it :/
Will it be possible to beat out the dent or will I have to be looking at getting a new fender?
Here's a picture of the dent...
It's not too bad and at certain angles its almost hard to spot, but its annoying none the less. My new rims are coming and I want the truck looking good for its new pair of shoes.
whale
Bitterville
4.0L Gas Hog
What if you used a dent puller? You know, it welds a little stick onto the metal, and you use a slide hammer to get it out.
Will
Airmaster
South Florida
2013
Mazda,
Chevy
I'll have to look into that but I think a friend of mine told me those things are worthless, thats why I havent wasted time trying to track one down
CHKNFKR
73
Illinois
545 CID
There are four bolts on the top, two behind the turn signal, one under the turn signal, one on the bottom directly in front of the door and one on top that you have to open the door to get to. I think they're actually 8mm but 5/16" fits just as well.
CHKNFKR
73
Illinois
545 CID
And thre isnt anything attached to it. The battery tray, fuse box, etc, are all attached to the inner fender. The panel you want is bolted to that.
whale
Bitterville
4.0L Gas Hog
It easily pulled a dent out of my Triumph tank. Guess that's different than a fender...
Will
3.0ranger1227
11
3.0L
I want to say it's a weird size, maybe 7mm? also be careful two of the bolts hold the main distribution box on.
CHKNFKR
73
Illinois
545 CID
You dont have to touch that. Its attached to the inner fender. The only thing you have to remove to remove the fender is a headlight assembly. And its not even attached to the fender, it just covers up the two bolts you need to get at.
straycat
77
02 06 and 2012
Jeeps
My buddy had a dent just a bit bigger than yours on his F150 near the bumper area, too. He called Dent Master and a guy came to the house and popped it out for him. It was about $70.00 for the call. My buddy told me that was worth it. He was going to take off the front fender and he said that was time consuming to him. It did not need any paint repair. Dent Master can do paint repair as well on a call.
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
while there is some good info on removing the fender,and even options for taking care of the dent.....
it still begs the question.....................
WHAT THE HELL IS THIS THREAD DOING IN THE 'FABRICATION' SUBFORUM?
thank you.[/rant]:icon_welder:
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
unscrew the inner fender, reach up in there and push the dent out by hand, a stud welder is for panels where you can't get to the back not an easy to access front fender, not to mention for stud welders you have to grind down to metal and fill with bondo because you can't get it smooth...
CHKNFKR
73
Illinois
545 CID
The inner fender is welded to the cab and the core support. He would need to remove the dented panel as described above.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
the plastic inner fender, I know the support goes from the cab to the core support, but there's room for a hand between the support and fender, it won't take too much to get the dent pushed out, maybe a rubber hammer handle pushing from the support to the fender or a 2x4
3.0ranger1227
11
3.0L
Actually where are you located OP? I've got a pair of red front fenders.
Will
514
Gnaw Bone, Indiana
Toyota
I was just about to make a post about Rain-X here, but I guess I'll hold off as that doesn't seem much like fab either.
