Which tool is correct?
zekew64
Carbondale, IL
2.3L I4, rebuilt from a '91
Hey all. I'm posting this here because I need some info regarding the crankshaft timing sprocket/gear and removing it.
I've seen two tools available to do the job, but cannot find the info needed to tell if either tool will fit my engine (Lima 2.3).
The tool numbers are as follows:
1) Tool T74P-6306-A
2) Tool T77F-6306-A
(Note: Both tools are different designs made by Ford OTC/Rotunda.)
The question is: Which tool is proper to remove the crankshaft timing sprocket/gear? For engines that have been around since 1983, this tool is scarcer than hen's teeth.
8,374
Neither is need for timing
These are used to remove the crank's belt gear if it was damaged or you wanted to replace the front main seal
This "gear" can usually be removed using a screwdriver carefully to slide it forward, turn crank pry it, turn crank pry it, ect........
If it is stuck and you have to take it off then T74P-6306-A is the correct tool
You can use a puller(two jaws) if you grind jaws down to fit, you can get pullers for under $20 and use those jaws to make ones that fit
tomw
46
lima bean
vertical and above ground
As Ron noted, they are scarce because they were not bought by even the pro's doing the work on the Lima. The sprocket is not a 'press fit' nor even a real tight fit, though I don't know the name(interference fit?), but should be retained by corrosion from the slow oxidation that takes time even when dry. When in use, it is compressed in place by the pulley bolt torque and that compression friction takes up the load from moving the timing belt.
tom
zekew64
Carbondale, IL
I know neither is needed for the timing job itself.
The problem is, I've seen the T177 tool online for $20, while the T174 tool is, minimum, over $100.
From pics, the 177 looks like it *could do* the job...but with no specs on the gear side of the tool, I can only speculate. And I need the tool because in tearing down my motor, I broke into multiple pieces the aluminum front main seal housing -- trying to remove a 25+ year-old timing gear that was seized to the crankshaft. So now I need that tool to replace the carrier for the front main seal.
tomw
46
lima bean
Could the bearing press tools at HF do the job? A split-piece that slides in from either side, and can be tightened? I haven't had the treat of removing one in a while.
tom
3,614
tom
Probably not enough room for that.
I have limited experience on that engine, but I have a few smaller guillotines and I have a hard time picturing either of them fitting in that spot.
scotts90ranger
4,548
Dayton Oregon
2.3 Turbo
no room for any tools that I have found, there's like 1/16" or less behind the crank pulley for the timing belt, I know, I had one that stuck pretty good a few years ago... I ended up breaking the front seal housing I think or at least pulling the oil pan and destroying the front seal from the back, it was bad... might have had the crank loose, don't remember...
The front seal housing conveniently has a loop around the timing belt to protect it, you get about 90* of access all pointing up and with a soft aluminum housing to pry against...
Like said, it is supposed to be a loose fit just located with the woodruff key on the crank. Conveniently the pulley is hardened and not really drillable and takes a LOT of time and cut off wheels with a dremel to cut through (did I mention I had a hard time?). but on a running engine this shouldn't be a problem... the engine I was working on had a engine fire at some point and had been sitting in a puddle of water for some time with the crank down and the front crank pulley not installed...
