Wont start. 2.9L
MoonKnight13
Changed the starter solenoid and now it.wont start. Anyone have any wiring diagrams?
MoonKnight13
Well it turns over when bypassed. S its either the solenoid or the switch wiring.
The large post close to the battery gets all the wires except for the one to the starter. The other large post gets the wire to the starter.
The little post gets the little red and blue wire with the push-over elbow.
Also, check the surface behind the starter relay (the solenoid is the little cylinder (not visible on the 2.9 starter) on the starter, it's what kicks the drive out, the piece you are working on is a relay). It grounds through it's contact to the fender on the flat back side, and won't work if it doesn't have a good ground there.
8,372
Yes ^^^
Battery + goes to large post on Starter Relay, all the other smaller wires attach to that same post, that's the power distribution for the vehicle.
The other larger post is for the large cable that goes to the starter motor, it will be the only cable on that post.
Small post on Relay is labelled "S" that connects to the Key switch, when that post gets 12volts Relay will close and starter motor will activate
MoonKnight13
Everything checks out. Wirng is correct but wont start unless bypassed.
Has to be the ignition switch or neutral safety switch.
8,372
Reads that way.
If you have a test light put it on the "S" wire(disconnected from Relay), and then a ground.
Try turning the key to START, test light shouldn't light up if there is a problem with ignition switch(under steering column) or NSS(or clutch switch).
If it does light up then relay is the problem.
New no longer means "it works", New now means "never been tested", so grain of salt when assuming a new part must work.
If test light doesn't light up check fuses first.
What year truck is this?
Hunter71601
Maryland
2.9
I have almost the same exact problem
Yesterday I was working on my 88' 2.9 sprcab 4x4, we got the fuel pump to finally work properly, (still no spark) . However the next problem I'm taking on is the remote start "S" wire is on getting 7.85 volts, if that terminal gets full voltage then the starter solenoid closes, and truck cranks, neutral switch was taken off and tested "GOOD" . So I'm going with ignition switch, which may explain the spark issue. Good luck with yours, i will be back on it tomorrow, and update,
Hunter71601
Maryland
2.9
Ok update. The distributor was 180 degrees off. This is after the coil had to be replaced. Truck would start and run with artifical fuel. So tested then replaced hp fuel pump and truck now starts and runs off of its own fuel. With sayin that it drives,hell even 4x4 works. However engine could run alot smoother, its not backfiring at all i just kinda sounds like not running all cylinders, hasn t stalled out but has gotten down to about 400-500 rpms. I have a couple of ideas. Perhaps fine tune the timing, check the injectors , and etc. Opinons welcome.
