ran into somethin I didn't see coming. .swapping to 10" brakes
PetesPonies
25
east coast
Ranger
2.3l
I got a set of 10" rear drum backing plates. BUT . . the mounting is much wider than my Ranger housing. So . did Ford have a large bearing rear for Explorers? That is what these were supposed to have come off of. They are 10" x 2 1/2". I thought maybe a full size Ford truck, but they are 10", not 11". Anyone help with some info?
PetesPonies
25
east coast
Ranger
2.3l
So . I'm thinking maybe it was from a 31 spline rear, bigger bearing? Can anyone confirm?
stegomon
20
auburn/minot maine
fords and only
That I know of you need the backers and drums from a 7.5
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
Forum Staff - Retired
TRS Banner 2012-2015
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
Yes, 31 spline have a bigger mounting spacing for the backing plates.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
And the end bearings are bigger in the 31 spline. If you take a good look at the axle tubes the 28 spline version necks down towards the end where the 31 keeps the same diameter all the way out.
PetesPonies
25
east coast
Ranger
2.3l
I didn't realize the drum brake Explorers used a big axle as well. Oh well, time to switch for the right ones. Thanks
Sasquatch_Ryda
Ford Technician
OTOTM Winner
Solid Axle Swap
108
Terrace, BC, Canada
Engine Type
4.0L
2WD / 4WD
Solid Axle Swap 4x4
40s
Yeup you need them off a ranger.
Staff online
Members online
Shran
April Truck of The Month
