Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > 1983-2011 Off-Road & 4x4 Ford Ranger's
Notices
1983-2011 Off-Road & 4x4 Ford Ranger's Show of your trucks, or post your build threads. This is NOT a help forum. Post your questions in the Help Forums further down
Reply
Thread Tools Display Modes
Old 08-23-2012, 07:17 PM   #1
koa's93ranger
koa's93ranger's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger xlt supercab
I use this vehicle for: trail rig
koa's93ranger is on a distinguished road
Default koa's 93 ranger build
Finally starting my long overdue build thread. Stuck at work right now so pictures will come soon.
I found this gem hidden in a kids front yard at the base of the mountain.he didnt know what he had and what it was worth, and neither did i at the moment. got it for only $2,300 and 72,000 miles. not bad for a 16 year old truck.
its a completely stock 93 4wd extra cab 4.0L stick shift. i couldnt figure out why it felt like my motor was about to blow up at 60mph. come to find out, it had 456 gearing with lockers front and rear. couldnt figure out why someone would want that on a stock truck with only 31 inch tires. after some research, i found out that this was a forest service vehicle that only sat at a lookout tower, which explained the gearing, low miles and all the cut up radio cables i found under the flooring. so in my opinion, this was a steal. low miles, upgraded parts, amazing condition, not a spec of rust, serviced at all the correct intervals by the dealership, all for $2,300.
__________________
93 xcab 4.0 4x4 5spd. 5.5 superlift, 3 BL, 3 spacer. 36"sx on 15x12 alcoas. Endless cosmetics (mesh grill, led dome/cluster, buckets, 5% tint, tinted tails, hid, projectors)
D44/60 leafs in the works
koa's93ranger is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Supporting Member.
5% Rock Auto Discount Code: 20B2FF503DCF74 Expires: September 28, 2018
Old 08-23-2012, 08:10 PM   #2
Ford78
December 2012 OTOTM
Ford78's Avatar
Vehicle Year: 1999
Vehicle Make: Ford
Ford78 is on a distinguished road
Default
Sounds like u got a hell of a deal on the ranger. Can't wait to see the pics buddy
__________________
1999 Ford Ranger SAS 351w np435 np205 Dana 44/60 5.13 gears,spooled front and rear
http://www.therangerstation.com/foru...d.php?t=129530 <The Build
Ford78 is offline   Reply With Quote
Old 08-23-2012, 08:59 PM   #3
koa's93ranger
Vehicle Year: 1993
Vehicle Make: Ford
Default
Gotta get to my laptop and upload em all. Gonna take a while. Plus I have to resize all of them. Going to lowes tomorrow to get all the wiring for 50a. Took me a week of research to find what works for my situation. Leaf perches came in today
__________________
Old 08-28-2012, 12:33 AM   #4
koa's93ranger
Vehicle Year: 1993
Vehicle Make: Ford
Default
this is how i got it, minus all the decals i put on it. the flex on it wasnt very good. made me miss my toyota
soon after, i installed at lift at work during down time. 5.5" superlift and some 15x12 alcoas with 31x11.5 tsls
the first day of testing the new suspension, i blew up both front auto hubs in the snow hehe
going the back to the issue i had before with freeway speeds, i decided to fix that with some 36x12.5 tsl sx which required some very light trimming and eventually a 3" body lift and 2" steel washer spacer
test flex with new tires before trimming fenders
the tires ended up being wayyyyy too big for my wheel wells and the slightest flex would rip off my fenders. refusing to cut up a perfectly good truck, i went with 33s. they were the perfect fit in the fender wells and also allowed me to easily cruise at 100mph on the freeway.
after body lift and washer spacer install
i quickly grew out of the limiting ttb flex and the constant replacement of the front suspension and lack of alligning and tire replacements hurled me into the idea of a sas.
my tires were so wide and offset that it would put incredible pressure on the wheel bearings and cause them to heat up and explode. now every time this happened, i would have to pay for a tow, replace rotors that get gouged from the knuckles and from the races heating up and spinning, replace bearings, seals, cracked pads, hub lock rings that crack into pieces, warn hubs that actually crack in half right at the flange, and spindles after the bearing get so hot that it welds itself to it.
on more than one occasion, my wheel would literally fall of my truck, luckily every time this happened i managed to slow down before it did.
here is what it looks like after placing the wheel back on the spindle after it just fell off. hub shot 50 feet out into the desert after exploding. (look at the insane camber)
this did not make the best reliable daily driver and i missed alot of work doe to no ride. so after 2 years and over $2000 in parts, i realized that i could have already done a full sas. so i said screw it, ive had enough... retired the ttb, parked my truck, and bought a daily reliable car.
which bring us up to date....
__________________
Old 08-28-2012, 01:01 AM   #5
koa's93ranger
Vehicle Year: 1993
Vehicle Make: Ford
Default
my donor truck, step dads old 79 f250. was a perfectly good truck, but after he got his 76 f250, he parked this one for 3 years then just start selling parts off it.
oh well, worked out for me since i scored a free hp44 and d60
began my swap with some brand new chevy 64s with only 4k miles on em
__________________
Old 08-28-2012, 08:33 PM   #6
Ford78
December 2012 OTOTM
Ford78's Avatar
Vehicle Year: 1999
Vehicle Make: Ford
Default
Looks good! Hopefully it will cool off for ya so u can get to building!
__________________
Old 08-28-2012, 08:52 PM   #7
koa's93ranger
Vehicle Year: 1993
Vehicle Make: Ford
Default
Trying to put in at least an hr a day. But sun doesn't go down till about 8:45 and I work early so I don't have very much time to work
__________________
Old 08-28-2012, 08:54 PM   #8
koa's93ranger
Vehicle Year: 1993
Vehicle Make: Ford
Default
Since I've removed the d60, ive notice oil leaking from the center of the yoke, where the bolt and washer is. It's not leaking at all from the outer ring of the pinion seal. What can this be? I'd like to know before I tear it apart
__________________
Old 08-29-2012, 01:47 AM   #9
koa's93ranger
Vehicle Year: 1993
Vehicle Make: Ford
Default
I'm having one hell of a difficult time trying to set my rear perches. Can anyone shed some light as to how you take accurate measurements with the pumpkin in the way. Please be specific
__________________
Old 08-29-2012, 08:35 AM   #10
Ford78
December 2012 OTOTM
Ford78's Avatar
Vehicle Year: 1999
Vehicle Make: Ford
Default
I just measured from the brakes to the springs and made sure they were even on both sides.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2018 / 959 Media LLC / All Rights Reserved
