Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > 4WD Systems
4WD Systems Transfer Cases & Locking Hubs.
Reply
Thread Tools Display Modes
Old 12-05-2008, 10:54 PM   #1
kozak
kozak's Avatar
Vehicle Year: 97,79,87
Vehicle Make: Ford
Vehicle Model: Explorer, F250, Ranger
I use this vehicle for: Daily Driver & Bush Beast
kozak is on a distinguished road
Default Electric Transfer Case to Manual Transfer Case Swap
I have a 93 Explorer with the electric push button 4x4, Borg Warner 1354. I would like to switch over to a manual. I have found a manual transfer case from an 88 Ranger, I believe it would be a Borg Warner 1350. Is there any major differences between the two transfer cases? Another thing I would like to know is, is it a bolt in swap, or would I be modifying drive shafts etc. Is there anything else to the swap, other then bolting it up, and rigging up the shifters in the floor ?
kozak is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 12-05-2008, 11:30 PM   #2
mjonesjr
I dance with the Devil...
mjonesjr's Avatar
mjonesjr is on a distinguished road
Default
The transfer case is bolt in, but you have to find a shifter to work. I think there was like 20 something different shifters for the 1350.
You also have to modify the 1350 front drive shaft by shortening it 1".
__________________
I shall not surrender...
I shall not retreat...
I will stand here and fight...
Or I will stand here and die!
All men are created equal, then a few become firemen.
Support Our Troops!
mjonesjr is offline   Reply With Quote
Old 12-05-2008, 11:53 PM   #3
kozak
kozak's Avatar
Vehicle Make: Ford
Default
The person I got the 1350 from has an 88 Ranger as a part truck, so couldnt I just grab the shifters out of it? I have no problem hacking up my Explorers floor wherever the shifters need to go.
Thanks for the help, good to know about the drive shafts, luckily I know some good welders.
Old 12-06-2008, 04:39 AM   #4
Wicked_Sludge
Wicked_Sludge's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger, Flareside
I use this vehicle for: Attracting the ladies
Wicked_Sludge is a jewel in the roughWicked_Sludge is a jewel in the roughWicked_Sludge is a jewel in the rough
Send a message via MSN to Wicked_Sludge
Default
there arent even close to 20 different chifters. theres like 3. you need one from an M5OD truck (90+ is a safe bet). the shifter out of the 88 wont work, it uses a different transmission (the linkage bolts to the side of the trans.).
you can shorten the front driveline, or you can get one from a d35/1350 equipped truck (the d28 driveline is too long).
the hole is already in your floor. under your carpet there is a bolt-in plate that blocks the shifter holes. you just need to find the appropriate plate for your setup (auto/manual trans). it would probably be easiest to get the linkage, plate, shift boot(s), and boot trim all from the same donor.
it can be a bolt in swap, you just have to find the right parts.
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 12-06-2008, 11:20 AM   #5
Hahnsb2
Hahnsb2's Avatar
Vehicle Year: 88-95
Vehicle Make: Ford-Dodge
Vehicle Model: BII-Dakota
I use this vehicle for: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
Quote:
Yes it will...
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Old 12-06-2008, 11:28 AM   #6
surffishin07
surffishin07's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger Super
I use this vehicle for: Daily Driver/Toy
surffishin07 is on a distinguished road
Default
i did this swap on my 94 ranger with a 5spd. i got the case from a 88 ranger with an automatic. the only modification i had to do was swapping the rear output flange from my old case to the new one all that takes is a 30mm socket and some locktite. the shifter from the auto bolted to my 5spd and the drive shaft barely fit just do your measurements first. as for the floor pan i just cut mine with tin shears. good luck its not that hard just check everything first.
__________________
1994 Ranger Super Cab XLT 4.0L with Eagle rims and 31/10.50/15 Wild Country FW's!!
1987 Zuki Samurai 1.3L 5spd soon to be a monster...
surffishin07 is offline   Reply With Quote
Old 12-06-2008, 07:57 PM   #7
kozak
kozak's Avatar
Vehicle Make: Ford
Default
Okay, well today, I went to the local wrecking yard here. Found a 93 Explorer, same as mine, looked inside, seen the shifter, looked under neath, an behold the 1354 manual transfer case is still there. It looks mint, I am going to grab that tomorrow, as well as the shifter and floor plate. Would I still have to modify drive shafts, would I have to get one shortened, or get the one from the donor explorer ? Does anything need to be wired up ? I really appreciate all the help, thanks to all of you.
I would feel much better and safer with the 93 1354 then having the older rusty 88 1350 under the truck.
Old 12-06-2008, 08:06 PM   #8
mjonesjr
mjonesjr's Avatar
Default
If you have a Dana 35 front axle, then you wont have to modify the front axle. Just make sure you grab the front drive shaft off the Explorer if you don't already have a 1354 front drive shaft.
__________________
Support Our Troops!
Old 12-06-2008, 08:08 PM   #9
kozak
kozak's Avatar
Vehicle Make: Ford
Default
Yes, the front axle in my explorer is a dana 35, and I got a 1354 electric case, so does that mean the front drive shafts would be the same ?
Old 12-06-2008, 08:28 PM   #10
mjonesjr
mjonesjr's Avatar
Default
Yup.....
__________________
Support Our Troops!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
