06 ranger sport 3.0 rwd
justins81213
4
Cuba,Mo
Pulled my transmission and put in a used one. I got it in there and all hooked up fine. Went into park and cycled through all the gears. Now fast-forward a couple weeks and she no longer goes in park or first unless I get under the truck and move the lever. Then yesterday I got a code for a faulty neutral safety switch, so I guess my question is can I stretch cable trigger that code or would it for sure be the neutral safety switch. I only ask because prior to doing the swap I've previously had to tighten them Torx bolts up to get her to drop into first! Probably a stupid question especially after getting a code saying it's a neutral safety switch but would rather know for sure rather than throw more money into it! Any responses are greatly appreciated!
superj
2,624
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
does it start in neutral or if you are holding the key to start and move the lever through the slots?
thats normally how i tell if its a neutral safety switch
superj
2,624
ranger edge
none
none
235s
Try to see if you can adjust the switch a little. But usually starting in neutral means that switch is misadjusted, or bad. You can put a multimeter on it to check though.
