- May 23, 2014
- 167
- Kelowna BC
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- Around 6-7"
- Tire Size
- 38x15.5
Small update. I haven't had much time to work on it but I've made some progress. Got the Cherokee knuckles reamed for 1 ton tie rod ends and drilled for mounting stock Ranger brakes. Made a simple engine cross member (not welded yet), cleaned up the frame rails a bit more, and slid the diff underneath to start measuring for control arms, steering etc. Also got some Johnny Joints, a Rubicon Express track bar, and a Toyota steering box. Next will be reinforcing the frame for the track bar and steering box. Then i'd like to build a trans cross member that will clear my driveshaft with the doubler. After that its on to making the control arms. I think
