166 degree warn hubs
RangerRough
10
Edgewood Texas
245 CID
6.5"
35" KM3
hello community!
I checked the temperature of my new hubs when i was out today crawling around in a mixture of 4 low/high and my hubs were hot to the touch, so one side was 161 and the other was 166 degrees. I am running a 96 ranger 4x4 4.0 on 35's with the warn jeep hub swap. what is the normal temps on these hubs? I also checked the 2 axle/bearing retaining nuts, first one finger tight then the spacer/locker, and the second nut as tight as i could get it, i watched to make sure the first nut never spun when cranking down on the other. I also put a new bearing in the driver side packed with grease but i did not replace the race.... any ideas why they are so hot?
Junk Collector
Truck of Month
4,839
Rapid City SD
What was the outside temperature while you were out wheeling?
~160 degrees sounds fine to me, especially with what I'm assuming is probably 80-100 degree heat outdoors?
Your bearing locknut adjustment is not good, by the way. "Finger tight" is way too loose, especially with a new bearing. Follow the service manual process to a T for new bearings... used bearings, I tighten to snug with a ratchet and then back off 1/8 to 1/4 turn, spin the rotor, should get a small amount of resistance and zero lateral play
Thirdly, keep in mind that cheap parts store bearings and races are often a hair out of spec and a new bearing with a worn race is not a good combo. A new PAIR of SKF or Timken bearings and races is what's really needed to do it right.
85_Ranger4x4
17,929
SW Iowa
And the bearings that come in new rotors are not top shelf stuff.
I put new Bendix rotors in my truck, all four races were crude Chinese junk... that were promptly used as drivers to drive in new Timkin bearing sets.
