1993 ranger 3.0 4x4 66,000 miles has rough idle
93Ranger85
So I've got a rough idle issue I've replaced everything almost I've got new computer full tune-up new distributor intake gasket upper and Lower checked whole wiring harness no breaks or shorts all grounds are good timming dead on 10btc. I'm at a loss with my truck I've done everything my scanner will not let me comunicate with my ranger please I need ideas or solutions I've done compression check too it's all good
Sent from my LGMS323 using Tapatalk
Kona
06/2014 OTOTM Winner
Canada Military - Veteran
ASE Certified Tech
Kamloops BC
7"
35x12.50x15
For the issue with the scanner not talking to the ecm try replacing the maxi fuse under the hood for the ecm ( to test switch with a same color/amperage from say -- air conditioning or something else the truck does not need while running) I had that problem, and that worked for me.
