1993 ranger 3.0 4x4 66,000 miles has rough idle
93Ranger85
So I've got a rough idle issue I've replaced everything almost I've got new computer full tune-up new distributor intake gasket upper and Lower checked whole wiring harness no breaks or shorts all grounds are good timming dead on 10btc. I'm at a loss with my truck I've done everything my scanner will not let me comunicate with my ranger please I need ideas or solutions I've done compression check too it's all good
Sent from my LGMS323 using Tapatalk
Kona
06/2014 OTOTM Winner
Canada Military - Veteran
ASE Certified Tech
Ham Radio Operator
Kamloops BC
7"
35x12.50x15
For the issue with the scanner not talking to the ecm try replacing the maxi fuse under the hood for the ecm ( to test switch with a same color/amperage from say -- air conditioning or something else the truck does not need while running) I had that problem, and that worked for me.
