1999 5.0L Mountaineer Build - SAS with Tons
kris97ranger
36
lisle ontario
4 litre and 7.3 litre
16s thats whats on mine and i dont think you can even use the sticky balancing weights
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
Factory wheel was 16".
Brad, Rock has Timken unit bearings for $200 a piece and "budget" versions for $140 a piece. There is no way this thing will weigh as much as a loaded SD, I imagine the budget ones would be fine.
PlumCrazy
2014 Truck of The Year
177
Millersport, OH
Solid Axle Swap 4x4
Kris, Are you running aluminum or steelies?
kris97ranger
36
lisle ontario
Steel 16x10 3.5" back space
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
So 16" is for sure the limit.lol Sometimes a steel 15" will fit where an aluminum 16" was tight.
kris97ranger
36
lisle ontario
If the truck wasnt in a snowbank right now id grab a pic but id say theres like 1/8" cleance to the caliper max. Im not sure if you can grind and use a wheelspacer like a normal 60.
But then where do you find 15" 8x170mm rims lol
036speed
02/2013 OTOTM Winner
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
I plan on running 17" steels. However, I am going to buy tires first.
kris97ranger
36
lisle ontario
Ive been considering buying trail worthty fab re centrerd h1s. I dunno about there but up here most of the used 42-44s are 16.5"
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
17" Is the new 15" anyways.lol
I was wondering for myself.lol Thnking a narrowed SD60 with 5x5.5 pattern...and keeping my 15" TSLs
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
Those are the wheels I like. But not sure if I will find used 16.5 40/42s
:icon_thumby:
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
16.5 44 and 38.5s used to be everywhere on CL in the cut bogger or TSL flavors...but they seem to be getting scarce nowadays.
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
Just messing around a bit. We have had interesting weather causing a layer of ice to develop on my driveway.
First job
Flexing....
kris97ranger
36
lisle ontario
Get buildin stuff!
036speed
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
kris97ranger
36
lisle ontario
That big fancy shop you have doesnt have heat? Slacker...i know its cold i start work again monday :bawling:
