2.3 carb help. What are these gizmos?
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Well... accelerator pump is definitely toast. Fired it up and noticed fuel leaking out of the side of it and I could nudge the throttle ever so gently to increase rpms but hitting the gas at any speed resulted in it sputtering out. Vacuum advance is definitely not working either.
Got a new one coming tomorrow.
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Those older carbs used a leather accelerator pump cup. Sometimes you can get it working again by just flattening them out.
19Walt93
4,484
Canaan,NH
351
3"
235/55R16
I think the 5200 had a diaphragm type pump.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,514
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They do... I will bet the spring is in a least two pieces and a bit of a crumble pile settled in the bottom.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Ok here's a brain teaser for you. How do you set the crank/cam/belt timing on this thing when there are ZERO marks on the block. The pulleys have dots but theres nothing to line them up to on the block!!!
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
WAG: use a straight edge across the centerlines.
PS: I've never worked on a 2.3.....
I answer these in the hope of learning from more knowledgeable people. It makes me do a happy dance when I'm right.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I can get the crank at TDC using the mark on the timing cover. I can get the cam to TDC by using the straight edge on the 2 cam lobes with exhaust next to open. I cannot however get the oil pump/distributor gear right. There is no marks or tricks for this one.
I can get the distributor gear where I think it should be, rotor lines up with the #1 on the cap. But it wont run like this. It will only run by moving the #1 plug wire to where number 4 should be. Then it will idle beautifully but not take any throttle without dying.
I'm ready to set this thing on fire. I'd kill for a ECU...
Accelerator pump is fixed as is the vacuum leak and vacuum advance.
Btw wtf does wag mean...
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
Everything I find online says there should be little diamond shaped marks on the head and block to set the gears! Theres nothing!!! Aahhhhhhhhhhhh!!!!!!
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Stupid forum software or something will only let me like posts. I can't choose other options like most other people seem to be able to. Otherwise I would have given a sad face emoji.
The #1 is across the cap from the #4? For some reason that makes me think the distributor is out 180*. Not my strong point...
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
#1 and 4 are 90 degrees off... done been tried running 180 each way. It only likes being 90 off.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I've done the timing now 5 times, I can make this thing run with the timing set 5 different ways. But each time I'll get idle smooth, dies when you hit the gas. Im gonna re time it once more and gonna throw a fuel pump at it. If that don't fix it I'm pretty much done. I have no real tools here, not even a fuel pressure gauge. The thing has an aftermarket cam pulley, hobbled together random parts and it's about 20 years beyond my abilities. I also figured out why there's no marks to line up the pulleys, they are on the backing plate of the timing cover and its missing...
snoranger
Professional money waster
ASE Certified Tech
13,689
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The oil pump/ distributor gear... the timing diamond (some of them also have a triangle, ignore it.) should be straight up.
Josh B
1,987
Oklahoma
Looks like you've got it right there in that photo Dirtman, appears to be dead center halfway between the two bolts.
That should be TDC, then guestimate how many degrees it needs. From there you'll just have to go by ear.
Once at idle then pull the throttle and once more, split the difference maybe
oh gosh, the whole thing turns don't it :/
4.0blue98
I don't feel tardy...
702
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
It's been a while since I had my 83 with the 2.0L but this still sounds like a carb issue or fuel delivery. Seems like it wouldn't idle super smooth if the timing was off. I did the belt on my 83 a couple times and don't remember any issues like this.
Uncle Gump
Token Old Guy
13,514
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That is an advanceable cam gear... for degree change to cam timing
Edit... I used one on a 1.7 VW that was sold by FAT Performance. Maybe poke around Esslinger and see if they have instruction for their adjustable cam gear I will bet it is one of their gears.
