- Jun 2, 2012
- Reaction score
- 8,372
- Location
- canada
- Make / Model
- Ford
- Manual
You will need to run new wire from the transfer case speed sensor to the cluster, and cruiseI’m kinda dumb on wiring so I catch on slow. On the speedo wiring do I need to physically rewire it to the cluster (as in manually jump across the ecu)or just pull the ecu and be fine?
What year is the ZF5 and what model transfer case, BW1356?
What engine is in the 2001 Ranger now, if its a 4cyl then you may not need to do anything for speedometer, but long shot if its a 4WD, lol
