2002 Ecoboost swapped Ranger build thread
02 EB swapped ranger
13
Ubly, MI
2.0L ecoboost
Thanks for the information!
No problem! Personally I wanna see more of these swaps on the road. As of now I'm pretty sure mine is the only one. I've had a handful of people personally contact me about details on the swap and honestly I think at some point it would be fun as a little side hobby to fabricate custom motor mounts for this swap to sell for people that dont have a welder and all that. Thats the main thing that seems to hold people back. Aside from the motor mount being custom everything else bolts up fairly easily.
walthagl
Winter Park, Fl.
Sketch it up send it to me and I will create a drawing for you.
whagl@cfl.rr.com
Honestly, if I ever tire of the 4.0 and feel the need for more power it will probably either be this or a 4BT.
13
Ubly, MI
2.0L ecoboost
whagl@cfl.rr.com
I dont have dimensions on hand and tbh I dont really feel like working any more this weekend. Just spend 12 hours straight painting my truck yesterday.
26479
erl88
Carlisle, PA
I don't have much to add but just wanted to say thanks for your post!
I have a 2002 Ranger 2.3 Duratec that spun a bearing (at least I believe, haven't torn it down yet) a couple years ago. I've been saving it to do this swap (or the 2.3 ecoboost) once I get the time and money to start. I drove it until it died with 265k miles on it, and I just loved it too much to give it to the junkyard for $100.
My hope is to find a ecoboost mustang from copart or somewhere as a donor, and see how much I can swap from there. I had been searching for a while to find a thread with some more details on someone who did it, and finally find yours a couple months ago. So thanks for all the good info, as it will come in handy down the road (don't hold your breath for my build thread haha).
13
Ubly, MI
2.0L ecoboost
That’s great to hear that you want to do an ecoboost swap! Right now I think the only option for a 4 cylinder ecoboost swap that bolts right up would be something from a 15-16 mustang or focus rs. As of right now ford does not sell a controls pack for the 2.0, it’s been discontinued for some dumb reason. I heard from Mike Johnston at rebel devil customs in Indiana that there is some talk of ford re-releasing the pack however. No clue when, just a bunch of talk about it. But as for a 2.3 bolting right to the trans, it should work fine. BUT if you can find an ecoboost mustang with a 6 speed manual, I’d take that in a heart beat and use that trans. Even if you do have to make a custom shifter and what not it would probably shift worlds smoother than the ranger 5 speed. If you have any questions on your swap throw them my way and I’ll try to help as best as I can!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Bronco648
102
Chicago-land, Illinois
XL
2.3
15"
This has been a very interesting read. I'm a little late to the party here but I think you meant to post "2013+" when it comes to Escapes with an EcoBoost engine. My wife has a 2012 with the V6 but I know that the 4 cylinder unit in the 2012 Escape was not an EcoBoost.
2012 was the last year of the "boxy" Escapes (I believe last year of the original platform). 2013 Escape was "all new" and had the 2.3 and the dual turbo 2.0, IIRC.
13
Ubly, MI
2.0L ecoboost
Idk about dual turbo. only dual turbos ford has are the v6 ecoboosts and if I recall correctly their 2.2 (?) or whatever it is diesel they offered on the 2012-2017 or 18 rangers over in mexico or whatever. And you are correct about 2013 being the first technical year of the ecoboost, however I think there was a handful of 2012 that were the same spec as 13. 2013 was also the first year for the focus ST, and 2015 I think was first for the ecoboost mustang.
Bronco648
102
XL
2.3
15"
I may be wrong about the "dual turbos" the 2.0 has "twin scroll" technology which I may have misunderstood as dual turbos. Anyway, you get either a 2.5, 1.5 or the 2.0. The 2.0 is the engine that's rated to tow which is why I know a little about the engine line-up. My wife is thinking that she'll move up to an Explorer since the Edge isn't much bigger, inside, than her current Escape. The new Escapes are definitely smaller than her '12.
13
Ubly, MI
2.0L ecoboost
yeah twin scroll on an already extremely small turbo makes boost come on so quick. Like dangerously quick in some cases. If I throw my truck in 5th and lug it at 1200 rpm is can make 20 psi of boost, which in that case would cause low speed pre ignition and damage lots of stuff. Its best to rev these motors up to 2500-3000 rpm before you actually put them into lots of boost.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
@02 EB swapped ranger, did you ever say what transmission and rear gears you're using.
And no heat, but what about a/c?
13
Ubly, MI
2.0L ecoboost
No AC, I am however running an aftermarket heater core in the cab. Trans is a stock 2002+ 2.3 ranger trans. 3.73 rear gears and a 7.5 open diff.
Scatt515
Hubert, North Carolina
So this is the Ford Focus SVT engine?? I see you did mention it came out of a escape but i was unaware they used this zetec engine that long! And you used the stock 4 cylinder manual trans? I am really interested in this swap! nice work man
13
Ubly, MI
2.0L ecoboost
nope this is completely different than the 2.0 zetec. Aluminum block, timing chain, direct injection and all those other modern goodies. the zetec is a great platform but putting one of those in a ranger would be really complicated. rwd trans that mates to a zetec is really uncommon in the states
