33x12.5x15 on 15x7 wheel?
1993Ranger4x4
Firefighter
EMT / Paramedic
Hartford, CT
3.Slow
is it okay to put a 33x12.5x15 tire onto a 15x7 wheel? This will be mostly street driven so i wont be airing down much.
thoughts and opinions?
tmaxxman
PA
2.9L
my are on 15x8 no problems
RavoHimself
8
enfield, ct
i wouldnt. upgrade to an 8" wheel. it would be too hard to get them to wear evenly on a 7
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Yeah that's too narrow for it to wear properly (15x8 minimum).
If it was offroad-only, then the wear wouldn't matter as much.
mp3deviant721
24
Eau Claire, WI
2.3l of fury
You could get a 33x10.5x15 if you are set bent on using 15x7s.
59bisquik
April 2011 OTOTM Winner
Solid Axle Swap 4x4
I ran 32x11.50's on stock aluminum wheels with no issues. US2BTech used to run 35's on stock wheels.
cstishenko
Kelowna, BC
it is fine. dont listen to the naysayers.
the only thing i have noticed so far is that you do not use the tires whole contact patch when on the street.
this in my opinion is fine...
- you have the contact patch of 10.5 on the pavement (fuel mileage) as this is not a pavement race truck.
-whether you wear out the center of a 12.5 or a complete 10.5 is your choice. i like the look of the 12.5
-once and if you air down in the bush you have the full contact patch of a 12.5 tire.
-and because you are stuffing 12.5 on 7in wide wheel.... its like a poor mans bead lock, no more blowing beads even once youve aired down.
im happy and wouldnt go any other way :)
